02-20-2012, 12:50 AM | #1 |
fuel pump
Need a little help on fuel pumps. I need to put a electric fuel pump on a 6 volt system, it needs to be very low pressure and low volume. There are a lot more 12 volt choices out there. My question is can you run a 12 volt pump on a 6 volt system? If so what do I need to look for? My Model A's don't have this issue!
02-20-2012, 02:31 AM | #2 |
Re: fuel pump
Here is a picture of my installation as far back and close to the gas tank as I could get it. I didn't even have to drill a hole for the mounting bracket. I was able to use a hole already in the stock frame.
This pump is an AirTex 6 volt low pressure (2-4 psi) pump that cost me $60.00 available here: http://www.summitracing.com/parts/ATX-E8902/
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness Last edited by Old Henry; 03-03-2012 at 01:36 PM. |
02-20-2012, 08:47 AM | #3 |
Re: fuel pump
I have a similar set-up as Old Henry on my roadster. I put an on/off switch under the dash. Before shutting off engine I shut off the electric fuel pump to avoid any excess gas going to carb. Don't know if it's really necessary cuz it's a low pressure pump but I do it anyway.
02-20-2012, 08:52 AM | #4 |
Re: fuel pump
PO51 What makes you think you need an electric pump? If you have a problem descripe the symptoms and lets fix it. G.M.
www.fordcollector.com |
02-20-2012, 10:21 AM | #5 | |
Re: fuel pump
"Never complain,never explain"... Henry Ford II |
02-20-2012, 11:03 AM | #6 |
Re: fuel pump
Prof. Henry (The Roaming Gnome) "It is good to have an end to journey toward; but it is the journey that matters, in the end.” *Ursula K. Le Guin in The Left Hand of Darkness |
02-20-2012, 11:05 AM | #7 | |
Re: fuel pump
02-20-2012, 12:16 PM | #8 |
Re: fuel pump
Thanks for all your input. I agree with G.M. we would like to fix the problem. The issue is this is for a 1921 Nash Touring car, it has a rear gas tank and a vacuum fuel pump on the firewall. We have not had much luck rebuilding the pump. Our thinking is if we install a inline electric pump that is low pressure and low volume we can use it as a back up and or as a assist.
02-20-2012, 05:37 PM | #9 |
Re: fuel pump
PO51 I haven't worked on a vacuum pump for years and can't get a clear picture in my mind of them. I do remember they are fairly simple to fix. You need to find some people with the teens cars that have these types of pumps. A lot of time parts companies that handle parts of that time frame can put you in touch with someone that fixes or has parts for them. G.M.
02-20-2012, 05:56 PM | #10 |
Re: fuel pump
The pump does have to be hooked up black to negative and tan to positive as you said. It won't work the other way around as you have discovered. But, as you mentioned from my picture, that is exactly how mine is hooked up - black to the negative coming from the switch I installed under the dash board that comes from the ignition switch and tan to ground which is positive.
02-20-2012, 08:43 PM | #11 |
Re: fuel pump
Dear Henry!
Have you got both fuel pump? if mechanical pump fail, you use the electrical one? I have installed electrical, but it is disconnected. Now I am using the mechanical pump only, but electrical push more than 7 psi. I disconnected it because it need a return to the fuel tank. I think that I should install the electrical system in case the mechanical one fails. I need to put a switch? or How to to make the connection to pass from one to the other. Harylufa
I love my Ford V8 1946! Harylufa! |
02-20-2012, 09:24 PM | #12 | |
Re: fuel pump
02-21-2012, 08:56 AM | #13 | |
Re: fuel pump
02-21-2012, 09:23 AM | #14 |
Re: fuel pump
Old Henry, I recently put the same Airtex E8902 in my '36 (also positive ground) to serve as an emergency backup. I've put a short length of rubber fuel hose between the metal line from the tank and the inlet to the fuel filter (which sits ahead of the pump), just to make it easier to clamp off and change the filter
Adam
1936 pickup, stock, black 1965 Mustang coupe 289/4bbl, black/red 1971 Alfa Romeo GTV 1750 coupe, dark red/tan 1970 911E 2.2 litre dark blue/black 1968 BMW R50/2 US, black (m'cycle) 1967 Triumph TR6R , sea foam/cream (m'cycle) 2022 Royal Enfield Interceptor 650 red (m'cycle) 1974 Honda CB750 red (m'cycle) 2000 Kawasaki W650 blue/silver (m'cycle) |
