06-24-2010, 09:51 PM | #1 |
35 p/u bed
Well this is the most extreme modification I have made to the old truck did I disgrace it or preserve it? I have the intent of using it, not just tinkering. |
06-24-2010, 11:53 PM | #2 |
Re: 35 p/u bed
what did you put in it, it looks nice
06-25-2010, 12:06 AM | #3 |
Re: 35 p/u bed
This is a flash back for me of removing that brushed on undercoating from the 50's, and 60's. I spents days removing that stuff from a 34 coupe body, on my parets driveway. The next owner of this truck might not like you.....LOL....Ed
06-25-2010, 07:07 PM | #4 |
Re: 35 p/u bed
06-25-2010, 07:40 PM | #5 |
Re: 35 p/u bed
It's your truck to do with as you wish, however, you are screwing it up IMHO.
06-25-2010, 09:38 PM | #6 |
Re: 35 p/u bed
06-25-2010, 09:46 PM | #7 |
Re: 35 p/u bed
Aw, come on. A spinning bed would be cool! Last one I saw was after a looooong night of imbibing!
06-25-2010, 10:44 PM | #8 |
Re: 35 p/u bed
That tough coating is no doubt durable but I preferred to simply line my pickup bed with 1/2-inch exterior plywood. Panels bolt to stake pocket holes with carriage bolts and the whole assembly can be removed in minutes. Sliding things in and out is a joy as you know due to NO intrusive wheel housings. Love those early pickups. Ignore items in bed.
06-26-2010, 05:38 AM | #9 |
Re: 35 p/u bed
I did the same to mine - rhino lined the bed. Wish I'd done the running boards, but I painted them with aircraft wing-walk paint instead. That's proven pretty durable too. If you're going to use it as a truck, it's hard to beat the lined bed...
Daddy always said, "If yer gonna be dumb, you gotta be tough" and I'm one tough sumbitch! T5 Tech |
06-26-2010, 09:00 AM | #10 | |
Re: 35 p/u bed
That does look pretty nice but I would never have the wood when I just wanted to set somthing in there and then it would slide on that slick steel bottom & bamm ever heard that noise |
06-26-2010, 09:04 AM | #11 |
Re: 35 p/u bed
A truck is a truck. Some were actually pretty designs to look at but were still trucks. What good is it if you can't throw stuff back there and haul it around. Stuff scratches & dents the bed just like it was intended to unless you strap it down every time. It's a little hard to strap down silage, corn, or cow manure so that's why they were all dented up before you restored them.
06-26-2010, 09:14 AM | #12 |
Re: 35 p/u bed
I use my '36 all the time to haul stuff. I got commercial pickup-bed rubber mat material, about 1/2" thick and very durable. Cut it to fit the bed floor, sides and front; I leave the bed floor mat in place (remove it to wash the truck), takes just a few seconds to suspend the sides and front from hooks that attach to the stake pockets. Totally protects everything but nothing permanent done to the appearance. I highly recommend this approach
Adam
1936 pickup, stock, black 1965 Mustang coupe 289/4bbl, black/red 1971 Alfa Romeo GTV 1750 coupe, dark red/tan 1970 911E 2.2 litre dark blue/black 1968 BMW R50/2 US, black (m'cycle) 1967 Triumph TR6R , sea foam/cream (m'cycle) 2022 Royal Enfield Interceptor 650 red (m'cycle) 1974 Honda CB750 red (m'cycle) 2000 Kawasaki W650 blue/silver (m'cycle) |
