01-09-2012, 10:11 PM | #1 |
Floorboard bolts/cup washers
Can someone kindly post a close-up photo of the original floorboard bolts and ‘cup’ washer (wood to subrail). Have been told that even the best reproductions (A&L) are not correct. Seems these would be difficult for someone to see during judging but am curious as to what is ‘right’ … was there any differences during production (i.e. 28 vs. 30s, etc.)?
01-11-2012, 03:22 PM | #2 |
Re: Floorboard bolts/cup washers
I didn't have a repro part handy to compare to these original parts, but as I recall the repro washer is too small on the O.D. and too large on the I.D. I can get my caliper out to take measurements of these parts if you need me to. Of course the D nut pictured would be part of the subrail, but these parts were rusted together and stuck in an original 1928 floorboard I bought at a swap meet years ago. |
01-11-2012, 04:32 PM | #3 |
thanks, as always .. pix of repro below
01-11-2012, 04:42 PM | #4 |
Looks pretty darn close to me
01-11-2012, 04:43 PM | #5 |
These bolts are 12-24. Very difficult to find nowadays.
01-11-2012, 04:52 PM | #6 |
01-11-2012, 06:42 PM | #7 |
The most obvious difference is the repro washers are flat on top. The originals are clearly not flat. They are slightly cupped so the outer perimeter touches the surface of the floor board first. If Tom took a pic from an angle you would see the shape. It's important to note this is the same washer as used on the choke rod.
http://www.abarnyard.com/ |
01-11-2012, 06:52 PM | #8 |
Call me nuts but i tried to put that slightly cupped edge in on some of the repro cups with a socket..and a hammer... Worked out so so ...not bad.. good thing i just needed a few...l.o.l.
01-11-2012, 08:24 PM | #9 |
Same way I did it. Put the washer over the end of a pipe, dropped a screw through the washer and hammered to shape.
01-11-2012, 09:29 PM | #10 |
My Auveco cup washers look like original types, with the cup, "Japan on Steel",
part # is...112... Uhhh, how many for the front boards? Thanks, Dudley |
01-11-2012, 09:58 PM | #11 |
Dudley,
There are twelve #12 machine screws that are used on the front floorboards. |
01-11-2012, 10:22 PM | #12 |
anyone have an 'edge' shot they can post?
01-12-2012, 10:36 AM | #13 |
Photo Tip: A head-on camera shot will show the shape pretty well if the lighting comes from the side. Most automatic cameras use the built-in flash so that the lighting is very flat.
01-12-2012, 11:16 AM | #14 |
Here it is.
01-12-2012, 08:09 PM | #15 |
Marco said....
" It's important to note this is the same washer as used on the choke rod. " Marco, for ALL years? Thanks, Dudley * Tom, there goes the spares.....LOL * Last edited by d.j. moordigian; 01-12-2012 at 08:21 PM. Reason: more info |
01-12-2012, 09:19 PM | #16 | |
01-13-2012, 02:26 AM | #17 | |
The Auveco company is still around but their catalog no longer lists #112, wonder why?
What's right about America is that although we have a mess of problems, we have great capacity - intellect and resources - to do some thing about them. - Henry Ford II Last edited by Mike V. Florida; 01-13-2012 at 03:38 AM. |
01-13-2012, 09:34 AM | #18 |
These washers look a lot like the ones sold for sedan door hinge screws. Are they the same?
Doug
My '31 S/W sedan project:http://31ford.dougbraun.com My restoration diary: http://dougbraun.com/blog |
01-13-2012, 07:46 PM | #19 |
Doug
I kind-a-remember them on the doors hinges on my 28 roadster, when I was taking it apart. I would say...no....but I will look. Since Marco said the chock rod, I would think he would have included that info. * BTW...just looked at my Brookville body on my hi-boy, they are on the door side of the hinge,BUT...are NOT the same shape. Hope that helps. Dudley |
01-13-2012, 08:46 PM | #20 | |||
I dug out a few pieces and hope to take a couple pics to post over the weekend.
