Old 12-26-2011, 04:27 PM   #1
Tom Cavallaro
Tom Cavallaro's Avatar
Default Timing the model a....
Wow! I thought it was going to be easy....I'm trying to set the timing on my Model A, usiing the pin in the front of the motor, but can't seem to feel the notch is not easy to find in the flywheel. Does the pin drop in a good size hole or is it more of a feel type thing. I'm not feeling it....hard to hold the pin and crank at the same time. Is there an easyer way? I tried to place a screw driver in the spark plug hole but the screw driver only moves about a half an inch up and down...really at a loss now....HELP.
Tom Cavallaro is offline   Reply With Quote
Old 12-26-2011, 04:42 PM   #2
Jerry Parr WI
Jerry Parr WI's Avatar
Default Re: Timing the model a....
Some timing gears have the depression in the incorrect location and some are not very pronounced. I have good luck finding them with a pointed device like a phillips screwdriver. I have seen timing pins ground to a point but think it looks bad.
Jerry Parr WI is offline   Reply With Quote
Old 12-26-2011, 04:59 PM   #3
Mitch Bunkin in PA
Mitch Bunkin in PA's Avatar
As was mentioned, use a thin Phillips driver (I've used an ice pick or a long nail) because the hole is very shallow. Remove #1 spark plug. Put a long nail into hole. As nail first moves up a bit press lightly on Phillips & you should feel a slight dip. OR Put a thin, rigid metal ruler into spark hole, slowly turn with crank & stop at highest point. Often (for me) that worked too. Good luck.
WEBSITE=http://faculty.bucks.edu/bunkinm/
"Most people ONLY want to know
what they already believe and
nothing more."
Mitch Bunkin in PA is offline   Reply With Quote
Old 12-26-2011, 04:59 PM   #4
leo
leo's Avatar
I had the same problem. When I was assembling my engine I did not drill a large enough indent on my timing gear to easily identify the spot with the timing pin so I recently removed the timing cover and re-visited the deficiency.....problem solved.
leo is offline   Reply With Quote
Old 12-26-2011, 06:14 PM   #5
columbiA
It sounds like you were trying to find TDC on the Flywheelthru the inner starter bolt hole .Maybe just the way you worded it.Just push pin while slowly turning engine with hand crank & you should feel pin go in sleight depression in Cam gear.Once found,Ive made made the dimple a little deeper by useing a drill bit & turning it with my fingers as the gear is generally made of fibre.
columbiA is offline   Reply With Quote
Old 12-26-2011, 06:39 PM   #6
30ccpickup
30ccpickup's Avatar
Tom here are a few tips:
By removing Plug # 1 and shining a small flash light into the hole, it is possible to see the top of the piston when you are at Top Dead Center.
Similar to what Mitch said, you can use a coat hanger through plug one and feel where top dead center is.
If you remove all of the plugs it will eliminate the compression making it easier to crank and find the mark.
http://MODELABASICS.com/ How Things Work on a Model "A" Ford
Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles.
30ccpickup is offline   Reply With Quote
Old 12-26-2011, 06:49 PM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
If you go past TDC, then just put the car in 3rd gear and roll it back a little to roll the engine back. Best to not be pulling on fan blades, especially if you use an original fan as I do.
Old 12-26-2011, 06:53 PM   #8
mrtexas
mrtexas's Avatar
I use my eye to find the indent. Set at top dead center and look thru the timing pin hole. After you find it, dab a bit of white paint on it to make it easier to find next time.
mrtexas is offline   Reply With Quote
Old 12-26-2011, 07:56 PM   #9
Tom Cavallaro
Thanks guys...I'll go back tomorrow and try again. I used a screwdriver in the spark plug hole and watched it go up and down, but I expected to see a great deal of travel...not just a half inch up and down. Tell me...each time #1 comes to the top...is TDC???
Old 12-26-2011, 08:28 PM   #10
roccaas
roccaas's Avatar
Only once ever two trips. 4 stroke engine. TDC is both ignition (what you want), and the top of the exhaust stroke.
Pull off the distributor cap. When you crank the engine around and see #1 TDC, see if the rotor is pointing in the direction of about 4:00 as seen from the passenger side of the engine. That's TDC ignition as the rotor is set to send the current down to the #1 plug. If the rotor is at 10:00, you are looking at TDC on exhaust stroke.
Once you find the real TDC ignition, take a steel chisel and make a small nick in the top rear edge of the crankshaft pulley while looking straight down on the pulley (no parallax from looking from the side of the engine). Now you always know TDC ignition. Some folks put a dab of paint or WhiteOut on the crank pulley edge so they can wipe it away before a show or judging. I have a flat steel pointer mounted to the front of the engine lined up with the nick.
You will probably also be able to find the dimple in the gear at this point, and a quick twist through the hole with a drill bit will ensure you have two references for TDC ignition (sort of like wearing suspenders and a belt.)
Good luck!
20 years ago we had Johnny Cash, Steve Jobs, and Bob Hope. Now we have no Cash, no Jobs, and no Hope...please don't let Kevin Bacon die!
roccaas is offline   Reply With Quote
Old 12-26-2011, 08:40 PM   #11
Rusty Homestead Fl
Rusty Homestead Fl's Avatar
Sounds like your screwdriver is resting on a valve and not the piston top if it's only going up that small amount
Rusty Homestead Fl is offline   Reply With Quote
Old 12-26-2011, 09:15 PM   #12
Glenn C.
Glenn C.'s Avatar
Make it easier on yourself for cranking to find the dimple on the gear, remove all spark plugs to reduce compression
Glenn C. is offline   Reply With Quote
Old 12-26-2011, 09:44 PM   #13
Milton
Milton's Avatar
If nothing else works try the following:
First retard the spark and remove number one plug.
Turn the engine with the crank and you will feel each compression stroke.
When you don't feel the compression stop cranking.
Look in the plug hole towards the generator side and see if the piston top is visable.
If not turn the crank a bit and look again, if it is turn the crank until it is very close to the top of its travel.
Remove the timing pin and with a mirror look into the timing hole.
If you see a small indent that is TDC. If you don't, then position the crank so you can rotate it with the side of your knee.
Rotate the crank while looking in the mirror until you see the detent.
That's all there is to it.
Milton is offline   Reply With Quote
Old 12-26-2011, 10:52 PM   #14
Tom Wesenberg
I've never had a problem feeling the dimple while pushing the timing pin in and hand cranking the motor. Most of the time I do it with the plugs in place, but as Glenn mentioned it sure makes it a lot easier to crank over with the plugs out. I press the pin in with my left hand while I pull on the hand crank with my right hand.
Old 12-27-2011, 12:11 AM   #15
1931 flamingo
1931 flamingo's Avatar
What Tom says with the plugs out and dist cap off, make sure spark is RETARDED,
Paul in CT
Old 12-27-2011, 11:00 AM   #16
Marco Tahtaras
Marco Tahtaras's Avatar
I may be misunderstanding some of the suggestions but you would be lucky to get close to TDC by watching the piston through the spark plug hole. It can however assist you in knowing you are close to finding the indent in the timing gear. There is approximately a 15 degree range of crankshaft rotation where the piston will be within .010" of TDC.
Assuming the car is currently running you can use the location of the distributor rotor to know when you are getting close as previously suggested. My link below will offer more info which may be helpful.
Model A Ignition Timing
http://www.abarnyard.com/
Marco Tahtaras is offline   Reply With Quote
Old 12-27-2011, 11:15 AM   #17
son of 19
son of 19's Avatar
Here Is good tip a old timer tought me. and it works evertime. take the timing pin out and turn it around and and put it back in. now take a c clamp and put on the timeing pin and the timing cover and tighting it up to where it is snug. now pull the # 1 plug and turn the motor over when you reach TDC the clamp will fall off. look in the spark plug hole making sure you are at TDC. hope it helps.
son of 19 is offline   Reply With Quote
Old 12-27-2011, 01:13 PM   #18
Frank Miller
Frank Miller's Avatar
Here is a thread on the V8 side that might help if you cannot find any indentation on the cam gear.
https://www.fordbarn.com/forum/showthread.php?t=57144
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 12-27-2011, 02:10 PM   #19
Milton
Milton's Avatar
Exactly the reason. To get close and not go past the mark. It is a lot easier to be prepared to stop on the mark than it is to backup to the mark or crank it around again. The rotor is a better clue, and a lot easier, IF it can be trusted (i.e. the car was currently running).
Old 12-28-2011, 05:36 PM   #20
Tom Cavallaro
Ok gentelmen, I found it...pulled the plugs and it made it easier to turn the crank slowly. Pin bumped...so went around again slower and stoped. Checked down the spark plug hole, and was surprised to see the top of the cylinder back farther. I was riding on the valve. Just expected to find the cylinder right under the sparkplug. Thank you all. Tom
