Old 12-24-2011, 12:07 PM   #1
rogeroadster
rogeroadster's Avatar
Default Early Ford Tie Rod Ends
I did a search and came up with nothing so for the early Ford machinists out there - does anybody know the angle of the taper on an early ford ('40 - '48) tie rod end? Is a standard or special reamer available?
rogeroadster is offline   Reply With Quote
Old 12-24-2011, 12:35 PM   #2
Kahuna
Kahuna's Avatar
Default Re: Early Ford Tie Rod Ends
7 degrees. Standard Ford taper
Kahuna is offline   Reply With Quote
Old 12-24-2011, 02:21 PM   #3
nostalgia59
nostalgia59's Avatar
I've been using this one from Snap On for years... http://buy1.snapon.com/catalog/item....re&dir=catalog
nostalgia59 is offline   Reply With Quote
Old 12-24-2011, 03:08 PM   #4
rogeroadster
Thank you and Merry Christmas.
Old 12-24-2011, 07:29 PM   #5
33cabriolet
33cabriolet's Avatar
Speedway has both taper reamers and rh and lh taps for tie rods,when I bought Mine they were US made. John
33cabriolet is offline   Reply With Quote
