Old 05-07-2010, 09:22 AM   #1
Steve Plucker
Default 1931 RE-stamped firewalls...
Can someone explain the 1931 restamped firewalls to me.
Do show cars have these?
Which gastanks were they designed for?
Thanks.
Pluck
Old 05-07-2010, 10:12 AM   #2
JoeWay
JoeWay's Avatar
Default Re: 1931 RE-stamped firewalls...
Congratulations to Steve for the first actual Model A related post!!!
1929 Tudor
since 1962
Feather River A's
JoeWay is offline   Reply With Quote
Old 05-07-2010, 01:02 PM   #3
Jason in TX
Jason in TX's Avatar
The 1931 restamped firewalls were flat 1930 firewalls that Ford had left over when they went to the indented firewall.
You will occasionally see an indented firewall that has the flat firewall raised bead smooshed in the indented area.
These restamped firewalls were originally intended to be used with gas tanks with cabin side shut off valve, but after restamping them with the indention, they will be used with the tanks that have the fuel shut off valve in the engine compartment.
Ford was just using up existing materials before switching over to the ones designed to be indented.
Drive it like you know how to fix it!
DMAFC / OILERS CC-MC
Jason in TX is offline   Reply With Quote
Old 05-07-2010, 03:53 PM   #4
Mike V. Florida
Mike V. Florida's Avatar
Restamped firewalls are accepted for fine point.
Old 05-25-2010, 09:16 PM   #5
Bjerg_Menneskene
Bjerg_Menneskene's Avatar
Here are a couple of shots of the firewall of my Dad's sedan -- you can easily see the "plug" welded in to fill the old hole for the gas line and the flattening of the ribs
Bjerg_Menneskene is offline   Reply With Quote
Old 05-25-2010, 10:05 PM   #6
Jeff P. / MN
Jeff P. / MN's Avatar
Elrod has it historically right. There were about 5000 restamped firewalls. My S/W 4dr. (#4521989) had one, I didn't realize it until I restored the car. See the book "Henry's Fabulous Model A Ford" by Les Henry. There is a good explaination and a picture of a stack of firewalls. I have posted this info at least three times in the past 6 months!
Steve, please PM me for contact info, I have two early '29's with firewall dates etc. that I want to discuss with you
Jeff P. / MN is offline   Reply With Quote
Old 05-26-2010, 07:54 AM   #7
jw hash
jw hash's Avatar
Steve Barb Birt`s show phone truck has a restamped fire wall and they had even put the holes in it for the data plate, the judges at last years NWR in cottage grove dock it points for having the holes in it. I have pictures of it but I don`t know how to post them here but I can send them to you. John
jw hash is offline   Reply With Quote
Old 05-26-2010, 08:23 AM   #8
Jeff P. / MN
I found a picture of my restamped firewall on my '31 Town Sedan. The reproduction patent plate was installed in the same 4 holes that the original was in.
Old 05-26-2010, 10:27 AM   #9
foxfire42
foxfire42's Avatar
My restamped firewall is on a late 31 (Sept 1931 engine #) truck which further enforces the the fact that trucks got the left overs. Assuming the truck was actually assembled in Nov or Dec 31 (it had the Dec. version of the engine pans) they must have had a lot of early restamped firewalls laying around late in the year. Seems 5000 of them would have been used up long before the end of 31. Barb Birt
foxfire42 is offline   Reply With Quote
Old 05-26-2010, 10:34 AM   #10
msmaron
msmaron's Avatar
Send a message via AIM to msmaron
OK now i am couious... How can you tell if if is Re Stamped. What are the tell tale signs. Here is my firewall picture?
Mark
Mark Maron
Ill., Region MARC & MAFCA
MARC JSC Member MAFFI Trustee
National Facebook Admin.
https://www.facebook.com/groups/MARC.group/
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 05-26-2010, 12:22 PM   #11
Marco Tahtaras
Marco Tahtaras's Avatar
Mark
There are excellent photos already posted showing the traces of the flat firewall ribs.
http://www.abarnyard.com/
Marco Tahtaras is offline   Reply With Quote
Old 05-26-2010, 12:28 PM   #12
msmaron
msmaron's Avatar
Ok thank and i see now the photos and ribs... Mine is NOT a restamp
Mark Maron
A7191-Sport Coupe
29 Roadster
29-Town Sedan
