12-15-2011, 05:01 PM | #1 |
8BA-toploader
I know this has been done to death but I still don't get it!
I started my 8BA in my 41 pickup and found I could not put the 41(39?) top loader in gear. The 9" Clutch, pressure plate and flywheel are what came on the 8BA. I put in a new disc and had everything balanced. I fabricated a longer adjusting rod and adjusted it out another 1 1/2" till it will not adjust any more. Still no release. I was told it may be the throw out bearing. I really do not want to pull the engine, but if I have to I would like to get it right the next time! Any help appreciated. |
12-15-2011, 05:31 PM | #2 |
Re: 8BA-toploader
Can you look thru the inspection hole in top of tranny while depressing the clutch and observe the throw out brg as it moves towards the clutch p/plate fingers??
Paul in CT |
12-15-2011, 05:38 PM | #3 |
Re: 8BA-toploader
Yes it seems to move and I can see part of the fingers move
12-15-2011, 05:52 PM | #4 |
Re: 8BA-toploader
'41,
I'm running the same setup in my '41 1/2 ton. Everything went in and the '41 clutch release mechanism worked without any mods. I sure like the idea of observing the cl rel workings thru the insp hole. Charlie ny |
12-15-2011, 06:10 PM | #5 |
Banned
Re: 8BA-toploader
Is it possible the disc could be in backwards? I know some will go in that way, and will not release. I also think that there is a small or different throw out bearing that won't release. I'm no expert for sure, just trying to think of possibilities.
12-15-2011, 06:43 PM | #6 |
Re: 8BA-toploader
12-15-2011, 07:57 PM | #7 |
Re: 8BA-toploader
I believe the 8BA never had a 9in. clutch and pressure plate. The 8BA had a 9-1/2in. set up. The fingers on the 9-1/2 plate are a diffrtant length that the 9in. The 8BA had a differant TO bearing, The 8BA TO bearing will not work with the 41 trans shaft and TO fork. I have the 8BA flywheel redrilled for the 9in. pressure plate. Walt
12-15-2011, 08:31 PM | #8 |
Re: 8BA-toploader
Do you have to stock clutch linkage,If the trans has a lever on trans thats 39 style,and when used with 39 pedels the trans lever has to be shorter,because the 39 does,nt have much travel so the trans lever has to be shorten to 39 lenght.
12-16-2011, 01:58 AM | #9 |
Re: 8BA-toploader
You also could have a 49thur 53 car pressure plate,think its smaller,39 bearing is to big for it.
12-16-2011, 03:38 AM | #10 |
Re: 8BA-toploader
the driven plate maybe too thick if its been re-lined. check to see that the 3 fingers on the clutch cover dont go over centre when you tighten all the step bolts into the flywheel, if they [fingers] do over centre throw inwards or even look level with the spigot-spline , then that will be the issue, the throw out bearing should be ok, as an earlier observer noted, looking thru the inspection cover at top of trans will reveal much of the problem, good luck.
12-16-2011, 05:18 AM | #11 |
Re: 8BA-toploader
"Remember that when it comes to intelligence, half of all of us are below average." |
12-16-2011, 09:39 AM | #12 |
Re: 8BA-toploader
Another thing to look at is the shaft and "fingers" that move the t/o brg towards the p/plate fingers. There is a "pin" or bolt holding the fingers to the shaft. I've had this 'shear" off. Drive you crazy.
Paul in CT |
12-16-2011, 10:41 AM | #13 |
Re: 8BA-toploader
The big problem with the 9 1/2 inch Long type clutch is that the splines are for the little 1 inch trans input. The fingers on the preasure plate are designed for this smaller diameter input set up like Walt mentioned. The clutch disk can be modified to work but the pressure plate won't work on the 1 3/8 inch ten spline inputs of the earlier style transmissions. I suspect the fingers are binding with the input shaft or sleeve somewhere.
As Walt mentioned the most practical clutch pressure plate to use is the early 9 inch. It's the least expensive one to repair and most good machine shops can set up to drill any 8BA type flywheel to fit one. Kerby |
12-16-2011, 08:41 PM | #14 |
Re: 8BA-toploader
Looks like I should have checked with you guys BEFORE I installed the clutch.Hoop I have a long style clutch from the 8BA engine. Actually the 8BA came with a 3 speed side shifter included. I removed it because I wanted to retain the torque tube. I checked the availability on the 9". Disc 91A-7550, Release bearing 78-7580, Pressure Plate 09A-7563. The pressure plate was listed 1935-1940, should I be concerned because my truck and transmission are 1941? Are these parts what I need? The shop that did the machine work can drill the flywheel for the clutch.
12-16-2011, 09:22 PM | #15 | |
Re: 8BA-toploader
12-16-2011, 09:35 PM | #16 |
Re: 8BA-toploader
Thanks Walt I will order parts Monday. I'll keep everyone posted on what happens next
12-17-2011, 11:28 AM | #17 |
Re: 8BA-toploader
Some of the 8BA type engines used the older 10 inch long type clutch but only in pickups, station wagons, and police cars. The flywheels are harder to find now days and the 10 inch preasure plate is more expensive to get repaired than the 9 inch mostly due to the amount that are currently in service are lesser in quantity that the old 9 inch. The 9 inch Long type clutch is the safest bet now days.
Kerby |
12-18-2011, 01:18 PM | #18 |
Re: 8BA-toploader
8BA-toploader update.
Pulled the engine this morning. Attached is what I found. The heads of the small bolts were shiny and worn. They were also adjusted all the way in (clockwise). The T/O bearing was burnished on the outer edge. Am I one the right track pulling the flywheel and getting it drilled for a 9” clutch? Just need some assurance before I start spending money.. Thanks. |
12-18-2011, 01:44 PM | #19 |
Re: 8BA-toploader
In looking at the pictures, I'd say all you need to do is replace the pressure plate. Everything else looks good to me
12-18-2011, 01:48 PM | #20 |
Re: 8BA-toploader
Number 6 pic see the wear to close to center.You want a pressure plate with the finger out farther.About 1/4 farther out from center each finger.
