09-03-2011, 02:11 PM | #1 |
Shell Rotella T 30 wt in flathead?
Does anyone happen to have any experiece with Shell Rotella T 30 wt in a flathead V8? I use this in my Model A and T with good results and am considering it for my recently acquired 1950 Ford flathead V8 239 ci convertible.
Thanks for any assistance. |
09-03-2011, 02:20 PM | #2 |
Re: Shell Rotella T 30 wt in flathead?
I called Shell and talked to a rep and he said this oil still had adequate amounts of Zinc in it for the Flathead engines,..it is what I will use if I ever get the motor running. Hey! it's only been 5 years.....gimmie a break!!!... .......... Matt in Alameda
09-03-2011, 03:56 PM | #3 |
Not quite the same thing, but I've been using Mobil Delvac 15w40 in my flathead for the past several years. So far, so good.
09-03-2011, 04:15 PM | #4 |
i use rotella 15-40 in my 42--59ab with no issues. (i use combo weight because truck gets used year round.) as for zinc? there is enough for a working engine, but, imho, not enough for break-in on new engines. suggest a good zinc additive for this.
09-03-2011, 04:16 PM | #5 |
I use the Wally World brand diesel oil in all my stuff and the inside of those engines stay clean,Ts,V8s and a Packard
09-03-2011, 04:21 PM | #6 |
If, however, you're running an aftermarket cam and stronger valve springs, then you should use it. Rotella will not suffice in this situation, you need to add ZDDP as a supplement or use an oil like Kendall 20-50, Valvoline VR1 etc, which are premixed with required levels. |
