06-13-2011, 05:45 PM | #1 |
1937 Three Brush Generator Help.
I need some of your help Guy's! My generator on my 37 Ford isn't charging. At idle the ammeter gauge reads 0. When driving around 45 MPH the ammeter still reads zero. If I turn on the lights the ammeter does discharge. Any ideas? Bad cut-out? Thanks in advance!
06-13-2011, 07:15 PM | #2 |
Re: 1937 Three Brush Generator Help.
I'm pretty low tech, I think that I would remove the gen from the car and see if it will motor... Hook the field and armature together and hook up a battery, ground the case... it will spin at a modest speed. If it does, it should generate... Then I look at the cutout... I would think of a diode type replacement... Karl
06-13-2011, 07:39 PM | #3 |
You can take the top off the cut out and see what the condition of the insides are. You can also manually operate the cut out with the top off or use a jumper wire to bypass the cut out. If the points are burned you can try to clean them. I prefer to replace the cut out with a self contained, cut out looking regulator from here: http://www.funprojects.com/products/10505v.cfm
If the cut out isn't the problem, you will get to disassemble the generator and look further. Most likely either the brushes need replacing, which is easy and cheap, or someone put the battery in backward and burned up the generator, which is not so easy and not so cheap. |
06-13-2011, 08:07 PM | #4 |
A couple years after a rebuild the 3 brush generator in my 39 quit on me. I had already switched to the funprojects regulator. Turns out there was a lot of dust from the brushes preventing them from sliding and staying in contact with the commutator. A little contact cleaner sprayed around back there and I was back in business.
Tom |
06-14-2011, 11:20 AM | #5 |
The generator was completely rebuilt with new brushes, etc. The cut-out was replaced with a repro made in China. How does the diode cut-outs work? Any modification need to be done to use them? Thanks! Don
06-14-2011, 01:31 PM | #6 |
Hope this helps, and JMO. BTW, this info is in the owners manual.... |
06-14-2011, 01:37 PM | #7 |
Attn: bobH: I can move the third brush in any direction and it doesn't make a difference.
