Old 05-07-2011, 03:37 PM   #1
Lefty W.
Default FrankenVicky
Hello, all -
An absolute newbie here. Last weekend I took delivery of my father's Victoria. It was worked on a bit back in the 1970s when the car was forty years old. Well, another 40 years later, she could stand a complete re-restoration.
Allegedly a 1931 model.
But, the engine is a bit earlier:
June, 1929 perhaps?
I'm sure I'll be asking questions here soon enough. For now, I'm just happy to get my feet wet.
Last edited by Lefty W.; 05-07-2011 at 09:17 PM. Reason: I think I figured out how to add images to posts
Lefty W. is offline   Reply With Quote
Old 05-07-2011, 03:52 PM   #2
Clem Clement
Clem Clement's Avatar
Default Re: FrankenVicky
Looks very nice to me. Take your time to learn about her before you dissamble. Get some driving time with her. She will tell you if she needs work.
clem
Clem Clement is offline   Reply With Quote
Old 05-07-2011, 03:57 PM   #3
cradlescyth
cradlescyth's Avatar
From up hear in the East
enjoy!!!
cradlescyth is offline   Reply With Quote
Old 05-07-2011, 04:25 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
If my cars looked that good I sure wouldn't want to take them apart to restore them over again. I'd just lube every moving part and make sure the brakes and mechanicals are good.
Old 05-07-2011, 05:19 PM   #5
Mike V. Florida
Mike V. Florida's Avatar
Same here!!
Old 05-07-2011, 05:44 PM   #6
Steve Wastler
Steve Wastler's Avatar
Me too!!
Steve Wastler is offline   Reply With Quote
Old 05-07-2011, 06:03 PM   #7
Lefty W.
Trick photography. Up close, you can see the paint peeling and rust showing thru the unprimered body. I'd say she's about a 40-footer.
She does need some mechanical and electrical work. Ammeter doesn't budge, no horn, headlights or taillight, speedo stuck at zero, exhaust manifold is holey, intake manifold holding on by a thread, but hey, at least the dome light works.
I think I'll put her up on jacks and have a look at her brakes. They seem to hold o.k.
Old 05-07-2011, 07:37 PM   #8
Brian SATX
Brian SATX's Avatar
Join the Victoria Club and get all their reference material. Is it a flat firewall or indented? Does it still have the Victoria ID plate on it in the engine comaprtment?
Brian SATX
Brian SATX is offline   Reply With Quote
Old 05-07-2011, 08:05 PM   #9
85930tudor
85930tudor's Avatar
Send a message via Yahoo to 85930tudor
i would drive it and be proud!!!!
85930tudor is offline   Reply With Quote
Old 05-07-2011, 08:32 PM   #10
pat in Santa Cruz
pat in Santa Cruz's Avatar
there are lots of cars that first timers took apart ( it's very easy) and never put back together because life gets in the way unless you are totally committed to the restoration. Restoration is a big job and requires dedication and perseverance. Most disassembled cars end up sold as basket cases, often to rodders. I would get it running and enjoy it long enough to create a bond with the car. That bond will give you the commitment and impetus to complete a restoration should you begin one later on.
pat in Santa Cruz is offline   Reply With Quote
Old 05-07-2011, 09:12 PM   #11
Lefty W.
Flat firewall:
Appears to be a reproduction body number plate. There's no 190A -xxxx on the plate. The patent plate is original.
Thanks for the advice. I'm certainly going to get her drivable and play with her a bit before I consider tearing her apart.
I believe I DO need to do something about that exhaust manifold, however...
Old 05-07-2011, 09:57 PM   #12
pat in Santa Cruz
I wouldn't worry about those 2 bolts. The more common manifold problem is a sagging rear port, but if you have the reinforced 31 manifold, thats less common.
Old 05-07-2011, 10:10 PM   #13
Lefty W.
Sorry, the photo isn't very clear. I wasn't too worried about the missing bolts that hold the intake manifold to the exhaust manifold. Rather, my concern is the gaping hole in the exhaust manifold. You can sorta see it there to the right of that stud/nut on the left.
Old 05-07-2011, 10:32 PM   #14
pat in Santa Cruz
Oh, THAT hole. Yeah, that's a problem.
Old 05-07-2011, 10:40 PM   #15
Mike V. Florida
Absolutely!!! Join today!!
Old 05-07-2011, 11:08 PM   #16
Lefty W.
I presume you mean the International Model A Ford Victoria Association? I've got my application ready to go.
Old 05-07-2011, 11:26 PM   #17
Lefty W.
Here's possibly a bit more clear photo of my holey exhaust manifold.
See that carbon from the hole just above the stud/nut on the left?
So, does anybody have any recommendations as to a replacement?
Old 05-07-2011, 11:59 PM   #18
pat in Santa Cruz
snyders repro manifold is a good one. If you're a stickler for originality, the 31's had a reinforcement that made the rear of the manifold stronger. The appearance is that the curved lower edge is more squared off. If you want this feature, you'll have to find a good original. Once you get your replacement, the intake manifold must be assembled to it and no doubt you will have to have the manifold surfaced to bring the sealing faces into the same plane. Installing them with a difference of more than a few thousandths can crack the manifold, or at best result in a bad seal.
Old 05-08-2011, 12:24 AM   #19
Milton
Milton's Avatar
Start spraying the liquid wrench now. You will be removing the exhaust manifold so the four studs and the tail pipe clamp will be coming off. The good news is, that takes care of the two bolts that are twisted off in the manifold. Nice looking car and it should be a real treat to drive. Looking forward to future discussions.
Milton is offline   Reply With Quote
Old 05-08-2011, 01:11 AM   #20
Tom Endy
Tom Endy's Avatar
The body tag in one of the photos indicates the body was built by Briggs. The Victoria Association would be very interested in learning more about this car. To date there has never been a Victoria discovered that was built by Briggs. All Victoria's identified so far have been built by Murray. If the tag on your car is original and authentic, you truely have a rare car.
Tom Endy
Tom Endy is offline   Reply With Quote
