04-26-2011, 11:17 PM | #1 |
1929 130-A Deluxe Delivery Door Wood and Other Parts
City:
Gothenburg
State:
Ne.
Wanted used original floor wood for the cargo are of a 130-A Deluxe Delivery. Just need something good enough for patterns. Also need wood for the rear door and panel around the door.
Update: Found the wood patterns for the floor risers and the latch and hinge pillars, still need wood for patterns for the rear door itself and most of the wood inside of the quarter panels. Other Small Parts Wanted Interior Light Switch and Bezel 2 Outside Rear View Mirror heads (Same mirror as the 28-29 trucks, pickups and station wagons) Pic's below on some of the wood and the mirror head I am looking for. Thanks Rod 308-529-2467
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!! Last edited by Rowdy; 12-03-2014 at 09:51 AM. |
07-09-2011, 06:11 PM | #2 |
Re: 29 130-A Deluxe Delivery Floor
Rowdy. I used plywood then put the bed strips back & its hard to see unless under they are not correct. I had some origs but think i burned them as its the only 130 A in NZ. I recall there is pictures of an orig one in restorer that shows the floor. If you dont have pos i can dig out & check. Im looking for 130 B body now as one i inported from Canada is not nice in fact stuffed , cost a fortune to even try & Repair. Derek from a snowy NZ.
07-17-2013, 03:07 PM | #3 |
Sorry Derrick, Settling with plywood is not an option to do it right. Rod
01-10-2015, 11:17 AM | #4 |
From this pic I need the pieces above the beltline including the corner piece and the add panel vertical support. I have the rear vertical support, but it is broken, so could use the exposed length minus the tenon. Luckily I have the piece next to the floor (n0t shown) and the piece from the B pillar to C pillar at the top of the fender well. I need a pattern for the rear subrail under the floor. This is likely the MOST URGENT as I need to have it before making the side subrails to make sure the joints are tight. The side subrails I have are only on loan until mid March Need dimension of the toeborad and some details of how it was attached. I need the corner block and dimension of the floor boards. Note that the rear board may be different. Also were these ship lapped or tounge and groove?? Need all 7 of the pieces for the rear door. Basicly I need all of the pieces for the rain gutter support ( longer than the tudor pieces used in this pic) corner pieces and the piece from the roof opening to the rain gutter. The roof pieces for the opening are the same as the tudor along with the B pillars.
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!! Last edited by Rowdy; 01-15-2015 at 10:31 AM. |
08-04-2015, 09:42 AM | #5 |
I received prints from the Benson for the door and the rear floor riser. Still need dimensions for the floor wood. Unsure if it was 5/8", 3/4" or 1" thick. Also need the width of each. Any corner wood, the wood for the upholstery retainer wood from the B pillar back at the belt line and patterns for the rain gutter retainer wood. Making progress, but need help finding the rest of the wood for patterns. This wood is not made by any of the wood kit makers for other body styles. Thanks Rod
01-13-2016, 08:38 AM | #6 |
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!! Last edited by Rowdy; 01-13-2016 at 08:48 AM. |
