04-12-2011, 08:39 PM | #1 |
34 Cowl Light Mounting Question
Have a question about mounting the Cowl Lights on my 34 five window. Since I got the car the cowl light where missing. There is a hole in the side of the cowl that I assume they go into. Tried mounting them in the hole but the clearance to the door seems too close. Today I found on Mac's site rubber washers for the cowl lights. In the diagram they look tapered. Did a search on cowl light mounting and came up empty. Just wondering if some one could post a diagram on how to mount the cowl light with the tapered washers?
Thanks Rich
Illegitimi non carborundum |
04-12-2011, 09:04 PM | #2 |
Re: 34 Cowl Light Mounting Question
I have a 34 and mounted the cowl lights so that the tapered washer; larger side goes toward the engine , as the cowl is tapered slightly towards the engine hood, this makes them face directly forward instead of an angle...try that out ...
04-12-2011, 10:12 PM | #3 | |
04-12-2011, 10:19 PM | #4 |
Another example of the crap that is being pushed on us today as "exactly like the original". Not worth a crap.
04-12-2011, 11:29 PM | #5 |
If you look under the cowl you will see a reinforcing piece with a little hole in it ,this is to drill. All std cars had it so it should give you a idea were the light should be ,
04-13-2011, 06:54 AM | #6 |
04-13-2011, 07:48 AM | #7 |
I machined some spacers from black plastic stock with a different taper.I could not improve the position of the lights So back with stock .The angle of the stem and the mounting hole surface makes it hard to improve. Lee34
04-19-2011, 06:23 PM | #8 |
Got the spacers today and bummer they are soft rubber.
I will use them anyway because I don't have a choice. Let you know how they worked out. Thanks Rich
