05-15-2024, 07:26 PM | #1 |
33 Fordor windshield removal
After disconnecting the hinges, does the windshield frame slide off to the driver’s or passenger side? I’m assuming it’s slides on a pin as does the top of the hood halves.
Tim Carlig Last edited by dean333; 05-31-2024 at 10:20 AM. |
05-15-2024, 07:56 PM | #2 |
Re: 33 Fordoor windshield removal
Pull the pin in the crank out mechanism [little hinge] -remove complete windshield. There are corner screws in bottom section for glass removal. Hinge sections are welded to top of frame. Right?
05-16-2024, 11:29 PM | #3 |
Unhook the regulator either by removing the the two screws or driving out the pin. Take out the header panel and remove the two screws from each hinge then lift the bottom edge outward and the frame will come straight out.
I usually scribe around the edge where the frame tabs meet the hinges as guide for reinstalling the windshield frame. Saves some messing around getting adjusted. |
05-17-2024, 07:06 AM | #4 |
I was hoping the process could be completed externally without messing with the headliner. The reason for doing this is it’s a deluxe where someone painted body color over the chrome.
Tim Carlig |
05-17-2024, 08:35 AM | #5 |
Unless somebody changed up the interior; removing the header panel does not entail messing with the headliner.
05-17-2024, 09:12 AM | #6 |
If the outside of the frame is painted you can probably remove the paint without removing the windshield. |
05-31-2024, 01:25 AM | #7 |
Great info, I am going to be putting a Windshield in my '33 very soon. I think it is about time.
05-31-2024, 11:04 AM | #8 |
