Old 05-14-2024, 01:50 PM   #1
cavecreekjake
Default Mercury 312
Don’t have access to the car right now…so, question - is there a valley cover beneath the intake ? Or do I just need intake gaskets when removing the intake to access the valve train…?
Thanks
cavecreekjake is offline   Reply With Quote
Old 05-14-2024, 03:20 PM   #2
40 Deluxe
Default Re: Mercury 312
Thanks
There is no need to remove either the intake nor the valley cover. The rocker arms and pushrods are all accessible by just removing the valve covers.
If for some reason you need to remove a lifter, you will need to remove the camshaft and pull the oil pan. This is because the lifters come out the bottom only. They are called mushroom lifters because the base is much larger diameter than the body. They are solid (mechanical), by the way.
Old 05-14-2024, 06:31 PM   #3
cavecreekjake
Thanks…. Not happy to learn that, but hastbe done I guess..one ticking lifter, and hoped for a simple solution
Old 05-14-2024, 06:56 PM   #4
Alaska Jim
Alaska Jim's Avatar
1 ticking lifter on a y block ,it is probably out of adjustment. set the valve lash. ck a service manual for spec. Y blocks do not have hyd. lifters, they are solid lifters only. remove the valve covers and adjust the valves , it may save you a lot of work for nothing
Alaska Jim is offline   Reply With Quote
Old 05-14-2024, 07:11 PM   #5
paul2748
paul2748's Avatar
Stock spec for rocker arm gap,is .019. See if you can locate the noisy rocker and make sure the push rod goes up and down
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 05-14-2024, 09:55 PM   #6
fordor41
fordor41's Avatar
If you can't get rid of noisy valve train, remove rocker arm assy and check for excessive wear in rockers or the shafts. I tore into my 292 this winter and found 3 bad rockers and badly wore rocker shaft. replaced the shafts and 3 rockers and sounds great now. shafts and rocker arms are available on line. If you remove the rocker assy, the push rods may stick to the rockers or drop down past the lifters. . not to worry. a magnet will remove them. the push rods can only go down inside a couple inches. also replace all push rods into original positions.
fordor41 is offline   Reply With Quote
Old 05-15-2024, 07:11 AM   #7
dmsfrr
dmsfrr's Avatar
While you're in there you might check the loose / noisy one for a bent pushrod.
They can bend if a valve is sticking.
dmsfrr is offline   Reply With Quote
Old 05-15-2024, 07:13 AM   #8
cavecreekjake
Thanks guys…. Hoping it’s simply adjustment
Old 05-21-2024, 12:00 PM   #9
55blacktie
.019 is hot lash. However, Tim McMaster (y-blockguy.com) likes to tighten lash to .015 "to quiet things down) on Y-blocks with stock cams. Cold lash should be .001-.002 more than hot lash; however, there is very little expansion on engines with both cast iron block and heads.
55blacktie is offline   Reply With Quote
Old 05-22-2024, 10:56 PM   #10
fordor41
fordor41's Avatar
I watched the y-blockguy video and he set his lash at .019 I think. the truck sounded like hell. isn't .015 a tad tight?
Old 05-23-2024, 12:04 AM   #11
55blacktie
Tighter than what's specified in Ford manuals, but surely Tim knows what he's doing. He also said that he uses .020 lash for one of the aftermarket cams he uses, but he didn't say which.
Old 05-23-2024, 11:39 AM   #12
scicala
scicala's Avatar
I set my '55 272 at .015" lash cold. Sounds a lot quieter and runs just fine.
Sal
