Old 05-12-2024, 08:32 PM   #1
v8nut
v8nut's Avatar
Default What is the correct size bolt for "35 engine pan
The rebuilder of my 1935 engine used 1" long bolts on the engine oil pan. They bottomed out before they were fully tight and I have been chasing oil leaks for a couple of years before figuring out what the cause was. Should they be 3/4 inch 5/16x16 tpi or what? Are there any sources of the correct non marked bolts? Thanks for your help. Jim in San Jose
v8nut is offline   Reply With Quote
Old 05-12-2024, 09:03 PM   #2
DavidG
DavidG's Avatar
Default Re: What is the correct size bolt for "35 engine pan
5/16-18 x 3/4" except for one 5/16-18 x 1" bolt at the rear where the threades are in the pan, not in the cylinder block.
Old 05-13-2024, 12:29 AM   #3
cas3
Thats a shame that the rebuilder was not sharp enough to use the original ford bolts.
They have a thicker head, and are of better quality steel than what you can buy today
Old 05-13-2024, 06:58 AM   #4
Terry,OH
Terry,OH's Avatar
You can get a kit of the proper bolts from Third Gen Auto in Tenn check their web site.
Old 05-13-2024, 06:59 AM   #5
rockfla
rockfla's Avatar
Try Michael at Third Gen for the correct bolts both in finish and length
Old 05-13-2024, 10:05 AM   #6
marko39
I found a longer bolt installed where the starter bracket is, makes sense to me.
marko39 is offline   Reply With Quote
