05-12-2024, 07:35 PM | #1 |
Misc Model A Parts
City:
Marietta
State:
Ga
Price:
You Pick
This is a Name Your Price type deal. Let me know what you want something and for how much, and I'll let you know if its yours. I plan on throwing most of this stuff away if no one wants it. If you think you want something, but aren't willing to pay for it, just say "I'll take X, for $0." If no one has put in a bid on it a week or so later, I'll respond saying its yours. I prefer local pickup, but can ship at your expense if the part can fit in a normal flat rate box. This is a rough list of what is available. I will remove from it as items are taken. I'm only listing the 'big' items, but all items seen in the Pics are available. -2x Engine Blocks One has a broken head stud in one of the holes. Both will need decking/honning/etc...- Front Bumper Bars - Rear Bumper Bars - Flywheel x2 - Pressure Plate x2 - Valve Cover x2 - Oil Pan (early '28) - Camshaft x2 - Crankshaft x3 - Valve Parts - Flywheel housing - Cylinder Heads x2 - Piston Sets (3 sets of 4) - Generator (Unknown if works) - Starter (not working, for parts only) - Transmission assembly (i haven't taken it apart, no idea what it looks like on the inside. No oil came out when pulling the drain plug.) - Ring and Pinion for Diff (stock 3.78:1) - Timing Gear Cover x2 - Side Cover x2 |
