05-02-2024, 12:24 PM | #1 |
Is this a widow maker wheel?
It’s on a ‘33 BB truck, I’m just trying to figure out what to look for.
05-02-2024, 12:38 PM | #2 |
Re: Is this a widow maker wheel?
IIRC the bolt pattern for Ford big trucks changed after 1934. If that's the case, then no, it's not a widow maker wheel. But over on the Ford Truck Exchange there is a member Stu who goes by truckdog 62563 who can tell you for sure.
Making the simple complicated for over 30 years. |
05-02-2024, 01:38 PM | #3 |
External locking rings are still being used. When the wheel rim is split [in the middle of the circle], those use a 'widow maker' locking ring. Right? I have 2 of those on an old farm trailer. Newc
05-02-2024, 02:59 PM | #4 |
The Firestone RH-5° wheels (widow makers aren't the same bolt pattern as a '33 BB
05-02-2024, 03:55 PM | #5 |
The Firestone RH-5° wasn’t brought to the market until 1948. They actually called it the “Advanced Design” rim. The pre 1934 wheels have a 5 x 6 7/8” bolt pattern. Stu
Stu McMillan Marmon-Herringtons |
05-02-2024, 04:19 PM | #6 |
Here a YouTube on them https://justacarguy.blogspot.com/201...-is-known.html |
