04-04-2024, 08:41 PM | #1 |
V8 Rear Axle Width
It appears to me that the V8 rear axle is 1” wider than the Model A axle
Model A 52.5”, V8 53,5” measured from the end of the housing at the flange where the backing plates attach. |
04-04-2024, 09:32 PM | #2 |
Re: V8 Rear Axle Width
Which v8 rear? No numbers here, but the 35 to 40 is 3/4" wider (per side) than the early
v8, and 42 to 48 is wider yet. If you're building a hotrod, 35 to 40 is the most commonly used to give a little more clearance for bigger rear tires. Tell us what the project is for a better answer |
04-04-2024, 09:43 PM | #3 |
'42-'48 is 4" wider (2"per side). I have a 42-48 Columbia in my '28 A roadster p/u & the sides of the tires are just even with the fender bead.
04-04-2024, 09:49 PM | #4 |
Lengths of V8 Rear Axles |
04-04-2024, 09:55 PM | #5 |
Thanks Ray and Mercman for some facts!
04-05-2024, 10:56 AM | #6 |
04-05-2024, 11:15 AM | #7 |
Why don't you tell us what year V8 car you are working on? Then you will know what rearend you need to find. It seems pretty simple to me.
I think you might be over estimating the power you're going to get from your V8 engine project. Unless you are putting a blower on it? Piecing together your other posts, it seems perhaps this project is a combination of everything to build a hot rod? I could be wrong. Last edited by Seth Swoboda; 04-05-2024 at 11:20 AM. |
04-05-2024, 11:27 AM | #8 |
The number you need the seller to provide is:
"wheel mount surface to wheel mount surface" Armed with that number, you can determine how it will fit your project. If you had a picture to post it would help ID the axle too. Easy to tell if it is '32-'34, '35-'36, '37-'40, '41, '42-'48, or '42-'47 pick-up from the visual details. |
04-05-2024, 11:37 AM | #9 |
32-34 is the same width as A, the early V8 used the same rear axles as A, later in 32 the banjo was changed to be similar to later banjo’s but is a little more narrow, later gears need some modifications to fit in the late 32-34 banjo
04-05-2024, 11:52 AM | #10 |
I am not working on a V8 car I’m working on a Model A, I thought that was apparent by my repeated reference to a Model A axle, and saying that I wanted a stouter axle. I did not actually say that however. So This Is What I Am Trying To Do: I want to install an axle in my 1928 Model A RPU that is stronger than the stock model A axle. There are “modern” axles out there that fit but I would like to keep the banjo look. I know that I would have to deal with spring mount etc. All I’m trying to do is see if it will work width wise. Why does it matter? Because I have fenders and wide tires and clearance is an issue. I’m using Lincoln brakes which add 1 1/2” per side over the stock Model A axle. Does that explain my question about the possibility of narrowing a V8 axle. I am not trying to keep any secrets I am providing all the information, I am sharing everything that I know at this time.
04-05-2024, 11:58 AM | #11 |
Thank you Rich, thank you Kurt. The axle does not currently have hubs on it is why I can’t determine that face to face measurement. The picture in the Craig’s List ad is terrible so no info there. The seller is a nice old guy and I’m sure will try and help if I know what to ask. He has had it for so long he does not remember what it is. I did not realize that this was such a difficult question to answer, in my ignorance it did not occur to me that the V8 axles are not all the same length.
04-05-2024, 12:07 PM | #12 |
I have provided the only measurement that I currently have, the flange to flange measurement. I would assume that I could get a width of the banjo measurement and an axle tip to axle tip measurement. I think that the bottom line is that in stock form a V8 axle will not work for me because I do not have room for any addition width than what I have now. It was wishful thinking on my part.
04-05-2024, 12:59 PM | #13 |
I don’t know if I should ask this question here or start a new thread. If I were to narrow a V8 axle housing myself could somebody shorten the axles? Or could I buy shorter axles? Thanks Guys
04-05-2024, 01:06 PM | #14 |
Merc an, the measurements you have provided make no sense to me. They seem to narrow to be the housing itself but they are too long to be the actual axle shaft.
I have contacted the seller and he is going to get for me a measurement of the width of the banjo and the axle tip to axle tip. He does not have the hubs so there is know way to get a measurement using them. |
04-05-2024, 03:43 PM | #15 |
One thing to note - if it doesn't have rear hubs on it, then it is highly possible that the bearing surfaces for the rear hubs are rusted. While they can be machined and sleeved, this adds cost to the overall project. Some pictures of what he has can sure help. Also, keep in mind that a Model A mounted the rear spring over the axle - that is not done on any V8 axle, so either you'll modify the frame to move the rear cross-member back or you'll modify the rear end and spring mounts, etc.. So, there is more to know that just the width.
04-05-2024, 04:08 PM | #16 |
Is the OP putting a Model A body on a '32 frame? I've seen that done a few times. I'll assume the OP is using the Model A Frame.
It might be beneficial to ask in the Model A forum what rearend those guys use when installing a flathead V8 engine in a Model A chassis. Or maybe if you ask that question over there they'll send a mob after you? |
04-05-2024, 06:23 PM | #17 | |
You may be better off to switch to removable axles like Hot Rod Works does. |
04-05-2024, 06:44 PM | #18 |
Thanks to all for the assistance
04-05-2024, 08:08 PM | #19 |
Hot Rod Works technical info page has the overaĺl widths of all the banjo axles.
