03-31-2024, 12:45 PM | #1 |
Marvel Carb: Installing new throttle shaft
Do I just cut the old throttle shaft out and remove it to install the new one? Or is this the wrong part?
Going into a marvel carburetor |
03-31-2024, 02:22 PM | #2 |
Re: Marvel Carb: Installing new throttle shaft
The answer is yes, that is what you do
04-08-2024, 07:10 AM | #3 |
Is that a Marvel specific shaft ? Is it oversized , and is it from Renners ?
04-08-2024, 09:49 AM | #4 |
No remove the throttle plate screw and plate then remove!!
www.whidbeymodelaclub.com |
04-08-2024, 10:19 AM | #5 | |
It is not oversized and yes it came from Renner's Corner. I didn't see any oversized ones and renner's seemed to be the only one that had the shaft. The original throttle shaft in mine was a little over a thousands of an inch smaller in diameter compared to the one I just bought. The old one had just a smidge of play if you wiggled it back and forth. The bore in the carb body was in good shape, so I just left it alone instead of boring it out and putting bushings in it. Car runs smoother and runs better with the GAV closed about 1/4 turn less than what I used to keep it at. |
