Old 03-15-2024, 01:11 AM   #1
langus480
Default Generator to Alternator conversion
Hello and thanks in advance, is there anyone who makes an alternator that looks like the vintage generator?
Or at least combine an alternator into the generator housing so you have best of both worlds?
langus480 is offline   Reply With Quote
Old 03-15-2024, 01:58 AM   #2
jayg48anglia
jayg48anglia's Avatar
Default Re: Generator to Alternator conversion
Yes they do. I think they are called Power Master. Speedway motors sells them. They are not cheap. Hope this helps.
jayg48anglia is offline   Reply With Quote
Old 03-15-2024, 02:14 AM   #3
TomInCologne
TomInCologne's Avatar
see attached photo...
TomInCologne is offline   Reply With Quote
Old 03-15-2024, 08:16 AM   #4
old31
I have been using the Powermasters for years on many cars and they work well. I ground it to the front timing cover bolt closest to the gen.
Old 03-15-2024, 09:29 AM   #5
langus480
Thats great to see a practical method.
Old 03-15-2024, 09:30 AM   #6
langus480
Helps quite a bit...thanks for the reply
Old 03-15-2024, 09:47 AM   #7
Canton_Model_A's
Canton_Model_A's's Avatar
In a video from Paul Shinn, he recommended this product. The one listed is for 6 volt system and it is a low-rpm type alternator
https://heielectric.com/shop/alterna...re-alternator/
1929 Model A Tudor
"Stay away from negative people, they have a problem for every solution"
Model A Ford Club of America
Model A Restorers Club
Motor City A's Club
Canton_Model_A's is offline   Reply With Quote
Old 03-15-2024, 12:46 PM   #8
AL in NY
AL in NY's Avatar
I decided to run an alternator because at the time I purchased halogen headlight bulbs with the new Bratton's reflectors for better night vision. I don't like the looks of an alternator on a Model A. Somehow, I found that Russ Evans makes just what I was looking for, an alternator the looks EXACTLY LIKE a Model A generator. Russ Evans is in Simi Valley, California and makes this alternator with the correct cutout included. It's a 45 amp, 6 volt, positive ground unit that will pass fine point judging. It cost about $560.00 plus $27 shipping (in 2024). Russ stands 100% behind his alternators and will replace any defective units without question. He is a Model A guy and will build the unit for your car, just supply him with your month/year build date and he will make up one exactly as needed for your car. He doesn't have a web site or email, but he can be reached by phone at (805) 428-2564. He also makes a 12 volt, negative ground unit. I bought mine from Russ because I felt better about giving my money to him verse a big corporation. I purchased it in 2014 and have put over 15,000 miles on it without a single problem. The battery is always perfectly charged and I don't have to worry about driving at night.
AL in NY
AL in NY is offline   Reply With Quote
Old 03-15-2024, 01:31 PM   #9
ndnchf
ndnchf's Avatar
Originally Posted by AL in NY View Post
I decided to run an alternator because at the time I purchased halogen headlight bulbs with the new Bratton's reflectors for better night vision. I don't like the looks of an alternator on a Model A. Somehow, I found that Russ Evans makes just what I was looking for, an alternator the looks EXACTLY LIKE a Model A generator. Russ Evans is in Simi Valley, California and makes this alternator with the correct cutout included. It's a 45 amp, 6 volt, positive ground unit that will pass fine point judging. It cost about $365.00 plus $27 shipping (in 2014). Russ stands 100% behind his alternators and will replace any defective units without question. He is a Model A guy and will build the unit for your car, just supply him with your month/year build date and he will make up one exactly as needed for your car. He doesn't have a web site or email, but he can be reached by phone at (805) 428-2564. He also makes a 12 volt, negative ground unit. I bought mine from Russ because I felt better about giving my money to him verse a big corporation. I purchased it in 2014 and have put over 15,000 miles on it without a single problem. The battery is always perfectly charged and I don't have to worry about driving at night.
Please share some clear, close-up photos of this unit. Thanks.
ndnchf is offline   Reply With Quote
Old 03-15-2024, 01:43 PM   #10
AL in NY
AL in NY's Avatar
Here are some photos of the Russ Evans alternator.
AL in NY
Old 03-15-2024, 01:51 PM   #11
ndnchf
ndnchf's Avatar
Thanks - that does look very nice.
Old 03-15-2024, 03:01 PM   #12
Ruth
Nice unit but doesn't look vintage as OP asked.
Ruth
Old 03-15-2024, 03:03 PM   #13
Ruth
Al, thanks for mentioning Russ, I was trying to remember where I bought mine. Excellent unit.
Ruth
Old 03-15-2024, 06:01 PM   #14
JOES31
JOES31's Avatar
The Powermaster unit looks darn close. I recently installed one and couldn't be happier.
Go with it!
JOES31 is offline   Reply With Quote
Old 03-15-2024, 06:20 PM   #15
Y-Blockhead
Y-Blockhead's Avatar
I also have a Powermaster PowerGEN. Mine is 12v, been on my Town Sedan since 2017. Only issue I had is the PowerGen is a little larger diameter than the Model A generator and the case hit the engine block when first installed.
I bought it off of Amazon.com, free shipping saves a few $$.
https://www.amazon.com/Powermaster-P...4-dc28e6d374b3
Old 03-18-2024, 09:03 PM   #16
langus480
I just saw Paul Shinn and youtube use HEI's alternator, what a coincidence...
Old 03-19-2024, 09:28 AM   #17
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
I have used several of Russ' conversions, -and he even makes a Powerhouse alternator conversion.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 03-19-2024, 09:17 PM   #18
langus480
Is there a link to the Russ Evans alternator or some way to be able to contact them for purchasing these?
Old 03-19-2024, 11:42 PM   #19
Y-Blockhead
Here ya go...
File Type: jpg Screen Shot 2024-03-19 at 9.39.20 PM.jpg (21.6 KB, 115 views)
Old 03-20-2024, 10:38 AM   #20
AL in NY
AL in NY's Avatar
langus480: go back and re-read my post #8..........
AL in NY
