03-08-2024, 05:20 PM | #1 |
Help Identify V8
Rookie here! Been reading a lot and still a lil bit confused.
36 dump truck. ( i think). Frame stamp by steering gearbox BB18 2432399 Engine: see attached photos. 21 stud, 2 water petcocks at 45 degree angle. Water pumps are on the heads. Block water pump locations plated off. If there is a crank vent at front oil pan corner, i cant see it due to grease. Have found a few stamps on top of block, but no “LB”. 1. What is the year of this engine? Everything has dual belt pulleys, except the generator has a single belt pulley. Fan is attached to generator. 2. So did they only run one belt? Cleaned plugs; marvel oil in cyls, set points total dwell, and it runs pretty good. I will pull her down and go thru it. 3. Radiator has a semi circle tank on top to match the high mount of fan On gen. Is this right? I enjoy reading all your wisdom, just hoping yall could help me dial it in. Jimmy Gulfport,Ms |
03-08-2024, 05:32 PM | #2 |
Re: Help Identify V8
Me being a Rookie also, I asked the same question recently. The guys here told me to look on the bellhousing and there will be a number there to identify the motor. I took the cover on the floorboard of my truck to look at it. Not sure if your truck is the same.
IMG_9540.jpg IMG_9528.jpg |
03-08-2024, 05:35 PM | #3 |
That is a ‘37 or ‘38 engine. No other 21 stud had front block water pump location. The block off plates were a ford part available to provide newer short blocks for older bolt-ons.
Ken, the large 59 on your bell housing is the only ID in that location that identifies engines, which tells you that your block is from ‘45 to ‘47.
Alan |
03-08-2024, 05:35 PM | #4 |
With the water pump block off plates, that would make it a 37-38 engine with early heads installed
03-08-2024, 05:47 PM | #5 |
Crank and water pumps set up for dual belts.
But fan is on gen; So only one belt can be used. Just used what they had? Or truck modified over the years? |
03-08-2024, 05:48 PM | #6 |
03-08-2024, 06:07 PM | #7 |
03-08-2024, 06:14 PM | #8 |
The generator pulley should be double groove as well on a truck. Generator was likely replaced at some point with "what they had", thus the single groove pulley.
03-08-2024, 08:31 PM | #9 |
Jimmy, perhaps I didn't make my post clear. Your engine is a 37-38 which was supplied as a short block replacement for your truck. Your bolt-ons such as the heads and manifolds are from the original '36 engine. The generator fan mount and radiator are correct for your truck. Don't bother to pull the inspection plate at the bell housing, you'll find no marks on your bell housing other than mold marks that mean nothing.
Alan |
03-08-2024, 08:59 PM | #10 |
37 38 eng best flathead ever built
03-08-2024, 10:49 PM | #11 |
Richard, who do you consider the 37/8 engines the best?
03-08-2024, 11:28 PM | #12 |
03-09-2024, 07:57 AM | #13 |
Archives of historical but relevant older articles: ------------- Hover mouse over the links below and click! ~~~~~~~~~~~~~~~~~--------------- Rumble Seat's Notes Techno-Source for the 1932 thru 1953 Flathead Ford |
03-09-2024, 10:52 AM | #14 |
Thank you for this!!
Reckon i will just run one belt; will go to neg gnd 12v so maybe i can find alternator kit that has a dual pulley. |
03-09-2024, 11:39 AM | #15 |
Another question:
I notice heads with rad hose in diff locations. Which scenario of water pumps and heads yields the coolest engine? Like: block water pumps & hose in center of head? But. Block water pumps require newer dist? Im not gonna work truck hard, but slow parades can be tough on em too. Thanks everyone! |
03-09-2024, 02:11 PM | #16 |
Not long ago I built a 59 block up withall 8ba parts. This was to imcrease preformance and save money. Block was bored to 3 5/16 8ba rods & ege pistond Eab cam & heads loadamatic dist and carb. Put it together for lassthan 3K and made alittle profit. Yes, I plug the hole.
03-09-2024, 03:38 PM | #17 | |
Alan |
03-09-2024, 10:48 PM | #18 |
Welcome to Fordbarn. It would be great to see a couple pictures of your truck.
If you want a resource of information about your truck (a Model 51 if it's really a dump truck) consider buying a copy of the 1935-36 Model 51 Truck book from the Early Ford V8 Club. It's $60 plus shipping which is some change, but it has lots of info. https://shop.efv8.org/collections/fo...-shipping-rate I'm happy to try and answer any questions you might have. Dave
1935 157" 1 1/2 ton stake truck undergoing full original restoration 1936 131 1/2" panel truck rescue preservation Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America |
03-11-2024, 05:04 AM | #19 |
I just so happen to have the correct, restored 2 belt generator and cutout for your truck. Here are a couple photos. PM me if interested. I can also email a video of it running on my test stand
Steve |
03-11-2024, 10:41 AM | #20 | |
