02-23-2024, 03:41 PM | #1 |
Throw out bearing/ clutch fork
I’ve been fighting “clutch chatter” since I bought my ‘51 coupe back in the fall. I older gentleman I bought it from purchased it from a friend of his and said the friend replace the clutch. When bought the car it had terrible chatter. I resurfaced the flywheel and replaced throw out bearing, pressure plate and disk. Which no change to the chatter. But at the time shoebox central was out of the hubs so I reused the old one. The hub had a damaged clip. Finally found a hub and bearing combo on eBay. So this afternoon I removed the transmission the old bearing and hub was trashed. When I tried to install the new hub/bearing it seems a little wider than the fork tips. My question is has anyone else had the same issue? I’m wondering if I the clutch fork I have is the wrong one. Or does everyone have to modify the clips to make them fit?
02-23-2024, 04:57 PM | #2 |
Re: Throw out bearing/ clutch fork
I’m hoping someone with better memory than me chimes in but I’ll go out on a limb and say you bought an early (large) throw out bearing and carrier . They changed sizes in 49 I think . All earlier (?) will be larger than the 49 up .
02-23-2024, 07:05 PM | #3 |
Well that’s what I’m afraid of. They sent me the wrong part and now I’m down until I can find the right one. Everybody that carries the bearing hub combination is out of stock.
02-23-2024, 07:12 PM | #4 |
can you push the bearing out of the hub and go to a auto parts stor to get a bearing.
02-23-2024, 07:50 PM | #5 |
Bearing isn’t the issue it’s the hub that is hard to find.
02-23-2024, 08:50 PM | #6 |
As always, a good source for oddball stuff like this is our own Fred Wilner at "Southside Obsolete", "barnfind08" on this forum. Have you tried "Third Gen Automotive"? |
02-23-2024, 09:27 PM | #7 |
I’m interested. Send me a message when you get home. Thank you
02-24-2024, 07:16 AM | #8 |
Try Southside Obsolete in MN
02-24-2024, 07:21 AM | #9 |
Deuce Lover I’m going to call them.
02-24-2024, 07:34 AM | #10 |
02-24-2024, 09:05 AM | #11 |
02-24-2024, 09:38 AM | #12 |
Deuce Lover I just sent an email.
