02-05-2024, 08:45 PM | #1 |
counter balanced crank
Is there a supplier in the Model A Kingdom offering a counter balanced crank? Years ago, there was an engine shop in Whittier California offering such. The owner died a number of years ago and the place went out of business.
Tom Endy |
02-05-2024, 10:29 PM | #2 |
Re: counter balanced crank
02-05-2024, 11:20 PM | #3 |
SCAT also makes one and there is at least one vendor selling the weights and will install them to the crank for a reasonable fee (the name escapes me at the moment0
02-05-2024, 11:32 PM | #4 |
OK,I found him. Check out DanFast he sells the weights that you can have him weld on or you can have it done yourself. He also sell balanced cranks.
02-05-2024, 11:39 PM | #5 |
Steve Becker at Burt's puts balanced cranks in his rebuilds, I suspect that if you called him he could give you a referral.
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan |
02-06-2024, 12:25 AM | #6 |
02-06-2024, 02:48 AM | #7 |
I have a Model B crank that is counterweighted. You cut down the mains to Model A size and use a det of B rods..
02-06-2024, 11:12 AM | #8 |
Apologies, it’s Dan4Banger that I have been trying to point you to (last night I said that it was DanFast (it was late, I was tired, oops). I think that he can provide anything you want in the area of a balanced crank
02-06-2024, 06:37 PM | #9 |
Tom,
The Burlington counterweighted crankshaft is an option also. I have used a number of them in the past. The link follows: https://burlingtoncrankshaft.com/ Good Day! |
02-06-2024, 06:47 PM | #10 |
You might check with Arlen Beiber (San Diego A's)
______________ Nothing Short of Right is Right |
02-06-2024, 07:13 PM | #11 |
If you can possibly afford it, call Snyders and buy the Scat crankshaft, and rods. Not everyone that supposedly has a super good reputation knows what they are actually doing. (Don't ask me how I know this).
02-06-2024, 09:13 PM | #12 |
It should be a punishable crime to grind a C crank down to 1.625 A crank size
I have put C cranks in A motors with inserts and a 1.850 main dia This allows for drilling to oil the rods and not comprising strength J
As Carroll Smith wrote; All Failures are Human in Origin. |
02-06-2024, 10:07 PM | #13 |
So a Model A block and main bearing caps have enough “meat” to be bored out to accept a “C” crank?
02-06-2024, 10:26 PM | #14 | |
The B/C crank has 2.0 mains If reduced to 1.85 it will fit The main caps 1 and 2 should be replaced The rear main of a later A has enough material The bearing inserts from a Saturn rod bearing work John
02-07-2024, 12:11 PM | #15 |
That is very interesting, thanks for sharing that.
02-09-2024, 09:02 AM | #16 | |
Good Day! |
02-09-2024, 11:37 AM | #17 | |
02-09-2024, 11:58 AM | #18 |
Why don’t you use the link that Dave thoughtfully provided and learn for yourself? I don’t think that Dan is trying to sell you one.
02-09-2024, 10:27 PM | #19 |
02-10-2024, 06:14 AM | #20 |
