01-12-2024, 05:55 PM | #1 |
New Blown Flathead
Will be building a new Blown engine. 3.312, 4-1/8 Scat stroker crank, running 5-6 lbs of boost.
Can’t find any Ross metric ring pistons in the size needed. Talked with Ross today and they have castings done, but machining won’t be done for 6-8 weeks. Talked with Scat and they are now making their own forged pistons Icon brand (part: IC626.std). The pistons are forged 4032 alloy with ductile rings, 1/16, 1/16, 3/16. Ross uses 2816 alloy with 1.5, 1.5, 3mm rings; moly coated top ring. 3/16 oil ring seems big Anybody have any experience with ICON Premium pistons and rings, particularly with 5-6 lbs boost. Thoughts JR |
01-13-2024, 01:58 AM | #2 |
Re: New Blown Flathead
we use ross forged ones in our blown flathead 13 psi boost no drama.
Lawrie |
01-13-2024, 02:44 PM | #3 |
Anything SCAT offers is going to be an off shore item. If you cant wait for the Ross pistons then contact EGGE and use there solution cast three ring pistons they cast them and machine them in house the 3-5/16 diameter and the 4 1/8 stroke is usually in stock. They come with Grant brand rings which feature low tension drag. Egge pistons will handle that boost level as well. I know from experience their pistons are worth looking into.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
01-13-2024, 04:21 PM | #4 | |
01-13-2024, 04:40 PM | #5 |
I have used Ross in the past with no problems.
I am using Mahle now with gas port rings. |
01-14-2024, 11:22 AM | #6 |
As noted earlier, I do like the metric rings, moly coated options, etc.. These are all coming from foreign piston applications. You have to determine your rings first, then the bore size. With Ross, I call them directly and work with them to specify the exact compression height, specific ring package, crown thickness (if blown), bore size (to match the rings), etc.. Regardless of who you use, it is very important that you determine the exact compression height you need for your crank, rods, block and heads - before you order pistons. I would not assume a stocking compression height will get your quench where you want it. Also, if you're running a heavily relieved block under boost, you might want to move the ring pack down a bit - to take some heat out of the top ring. On our blown flathead Cadillac Bonneville engine the latest set of pistons were made by Diamond. Diamond makes great pistons, but you'll be paying for them! |
01-14-2024, 04:09 PM | #7 |
Interesting conversation. I also used Ross with Total Seal rings and had to get them custom made. I believe it took an extra 3-4 weeks to have them made.
Any ever use Wisco automotive pistons? Back in my 2 stroker days, Wisco was the brand to use. I stumbled upon their site one time while looking for pistons. They are forged, but are more like a modern, short skirt type of piston. |
01-14-2024, 06:01 PM | #8 |
I've used ICON in 348/409 GM engines. They were solid items.
Mike Wanted: - '32-34 Open Cab Pickup (RPU) parts and documents/articles/info - ARDUN parts |
