11-25-2023, 08:43 AM | #1 |
What’s a good spark plug for a 36
Hi guys I recently acquired a 36 roadster deluxe, and wanted to know what are the best plugs for a 21 stud 36 motor? I know champion have had some criticisms so what are you guys using and have found works well? Thanks
"I have built my organisation on fear"..Al Capone. |
11-25-2023, 01:18 PM | #2 |
Re: What’s a good spark plug for a 36
I still use Champion 555 UD16. It has worked well in my 36. terry
11-25-2023, 10:56 PM | #3 |
Speaking from experience, what cylinder heads do you have? The Offenhauser heads take a plug with a half inch thread depth, the Edlebrocks take the 3/4 inch thread plugs. Put the 3/4 inch plug where a half inch plug goes and you get to rebuild your engine after you dig all of the spark plug debris out of the cylinder walls.
Steve in Denver |
11-26-2023, 07:02 AM | #4 |
Champion UD16. Have for many moons. Never an issue.
11-26-2023, 09:44 AM | #5 |
I have stock heads . Checking to see if there is something better than the champion for a 36 engine.
11-26-2023, 11:12 AM | #6 | |
I don’t know of anything you could improve on. Mine have performed flawlessly for many moons. If they are not working for you possibly you have other issues. |
11-26-2023, 11:55 AM | #7 |
I have found that "run of the mill" Champion plugs may suffer from poor quality control and manufacturing processes these days. However, I have not run into this problem with the rather specialized plugs folks like us use, and in fact, I prefer Champions in most cases. I use "L82YC" extended tip plugs in the Edmunds heads that I prefer and have found the completely satisfactory (the set currently in my '51 have been there since I installed the engine in 2016). Interestingly, all of these plugs I have purchased were made in France.
11-26-2023, 02:20 PM | #8 |
Better as in champion have suffered poor quality control and poor manufacturing processes.. I don’t have anything wrong with my engine. But of you do a search here you will see many have had an issue with champion plugs, so I asked what are the alternatives being used .
11-27-2023, 11:54 AM | #9 |
A good alternative is NGK A6....NGK AB6
11-27-2023, 12:04 PM | #10 |
I think the Champions most folks had issues with were the recent production H10's.
11-27-2023, 12:28 PM | #11 |
Autolite 386 for me all day
11-28-2023, 09:39 AM | #12 |
