Old 11-14-2023, 12:43 PM   #1
whygoby
whygoby's Avatar
Default 21 Stud Pressure Testing Plate W/Gasket
City: Sparks
State: Nevada
Price: $250
I'm taking orders to have a few 21 stud pressure testing plates made. These are invaluable for locating an engine issue, either in the cylinder head, or block. The plate is 1/2", with a 1/4" sealing gasket, both 100% accurate by scanning, and water jetted. I'm not supplying any block off plates, as 32-36 is different to 37 center outlets. If interested, text or call Doug 775-219-8241. Price will be $250 each.
A plate is already available for the 24 stud engine from Speedway, but the plate is only 3/8" thick, and costs $279. There are NO 21 STUD PRESSURE CHECKING PLATES CURRENTLY AVAILABLE!! (I just discovered a small pin hole in a combustion chamber, which saved me from pulling the engine)
whygoby is offline   Reply With Quote
Old 11-17-2023, 11:22 AM   #2
whygoby
whygoby's Avatar
Default Re: 21 Stud Pressure Testing Plate W/Gasket
Btt
Old 11-21-2023, 11:55 AM   #3
whygoby
whygoby's Avatar
btt
