11-11-2023, 08:30 PM | #1 |
Wheel bearings?
Where to buy wheel bearings, king pins and tie rod ends for a 50 Mercury? TIA
11-11-2023, 08:43 PM | #2 |
Re: Wheel bearings?
Try Ebay, NAPA, Fred Wilner Southside Obsolete. https://southsideobsolete.com/#front-end
1924 Model T Coupe 1928 Model A Roadster 1930 Model A Town Sedan 1939 Deluxe Fordor 1945 pickup 1951 Custom convertible |
11-12-2023, 10:09 AM | #3 |
Re: Wheel bearings?
Michael Driskell at third Gen
11-12-2023, 10:33 AM | #4 |
Re: Wheel bearings?
Shoebox Central:
https://shoebox-central.com/49-51-mercury-parts There are taper pins that you need to drive out to get to remove the spindle. You might be able to reuse. Keep track of your shims as well. The new spindle comes with new bearings, shims and taper drive pins. If you are doing wheel bearings, you'll need new seals
Henry Ford designed the flathead without the aid of a computer. |
11-12-2023, 11:44 AM | #5 |
Re: Wheel bearings?
Take plenty of photos as you perform the removal and installation of your front suspension spindle assembly. I found these books to be "a must" when I replaced the king pins on my 51 Merc. They have step by step instructions with photos which makes the job much easier. Buy them if you can. These manuals have tons of other information.
11-12-2023, 03:51 PM | #6 |
Re: Wheel bearings?
11-13-2023, 07:13 PM | #7 |
Re: Wheel bearings?
I found out the hard way that if you replace the king pin bushings that they have to be honed out before you install the new king pins.
11-14-2023, 06:07 PM | #8 |
Location: North Warrandyte, Melbourne,Victoria, Australia
Re: Wheel bearings?
Wheel bearing part number is: 88128R ( complete with locking collar/retainer),
Try& get either: FAFNIR/FEDERAL/L&S/NDH USA made brands or BCA/FAG GERMAN ONLY! NOT INDIAN/KOREAN/SKF european made , king pin bushings FORD part number: 8A-3110A. |
