11-06-2023, 02:55 PM | #1 |
handbrake on my '56 Country Sedan
Hi All-
I'm replacing the handbrake cable on my '56 wagon and could use some advice. I removed the old cable along with handle in the cabin. While I had the handle out of the car, the little ratcheting mechanism in the handle and its coiled return spring fell out before I could take a look at it and I'm trying reinstall it now. I see a half moon wear area on one side of the H shaped ratchet plate. I assume that side of the plate should face down and towards the rear of the car. My problem is where the coiled spring goes? The spring has a short and long leg. I'm guessing the short leg should push against the back side of the ratchet plate and the long side against the outside of the tubular shaped body of the handbrake. I think the pivot point of the spring should fit over one of the two pivot legs of the H shaped racket plate. But on which side? The plate slides in from only one side of the handle but placing the spring on the first H leg as it's slid into place wouldn't secure the spring and the plate from coming apart at a later time. So I think it must somehow slide over the other leg but I don't see how. Does anyone have a closeup picture of this detail? (Sorry for the long and confusing description.) |
11-06-2023, 05:27 PM | #2 |
Re: handbrake on my '56 Country Sedan
Well, I managed to try ever other way of putting it back together other than the right way. At last, finally got it back together and onto the car. Sorry for the post, I appreciate that there's a community out there willing to help a knucklehead like myself.
11-06-2023, 07:09 PM | #3 | |
- My 55 Tbird has a 56 ECZ-A block & a C2TE timing cover - |
11-06-2023, 07:15 PM | #4 |
As far as the H-plate, one end has partly rounded edges and the opposite end is sharp. The sharp end contacts the notches in the rail. |
