#1 |
Astra-Werke, owner of a 1930 Coupe in Germany recently produced this video. Shows his technique of dealing with modern urban traffic. This is a follow up to the recent thread Dealing with modern traffic which I can't seem to find.
https://youtu.be/G4ouqY7LrUw?si=rNG9pxB29zn33JVB |
#2 | |
![]() Quote:
A few years ago, we were in Beijing, China. At first take, the traffic was chaotic and without rules. It didn't take me long to work out that one toot on the horn meant something, Two quick toots, something else and that way, drivers communicated with each other without aggression. It worked very well.
#3 |
Wow and blinded by the sun to boot!
#4 |
First thing that I noticed is the lack of potholes.
Joe B in Michigan |
#5 |
On another note about the vid...background 'oldies' music...1st-Rebel Rouser; Dwayne Eddy, 2nd-Rumble; Link Wray, 3rd-?, 4th-ShhBoom; (forgot)
Can anyone complete the list? Craig |
#6 |
#7 |
Does Werner lurk on the Ford Barn? If so, I enjoyed his video, and it was ike driving in many towns in the USA. The camera makes the drive more dramatic than it actually was. I hope that Werner's Coupe has turn signals.
Not once did I hear the gears grind, and Werner's Coupe is less nosier than most Model A's. AzBob, thanks for posting Werner's video.
Bob Bidonde |
#8 |
The left lane is safer for a car with a longer stopping distance because you don't have people entering from or exiting to side roads in front of you.
#9 |
I agree. I thought the same thing ...and also I felt like the pacing distance was a little too aggressive for my liking considering there really was no place to maneuver to in case of sudden braking.
#10 |
These are all good points. I'd like to add that I have confidence in my brakes. Cast iron drums, and floaters. No more than my car weighs, I can lock the wheels if I want to.
#11 |
You ain't stoppin if the wheels are locked up. I trust my brakes too, but those skinny little tires only have so much traction
#12 | |
![]() Quote:
#13 |
The reaction time can be considerably improved by using your left foot for braking and clutching. Keep it just touching or just off the brake pedal. If you have to slam on the brakes for an emergency situation it does not matter if the engine stalls. Race drivers (sports cars with manual transmissions) will use this trick and move the left foot to the clutch when needed.
For modern cars with automatic transmissions the left foot on the brake works better because you don't have to worry about stalling the engine. Works best in traffic or situations where cars are entering or leaving the road ahead of you. For the case where there is no traffic you can take your left foot from just off the brake pedal to give it a rest. It gets tiring holding it just off the brake pedal.
