09-26-2023, 03:00 PM | #1 |
Speedometer Cable - right or wrong way to reinstall after lub.
Speedometer cable isn't spinning the speedo. I took the speedometer out and drove the car, and the cable wasn't spinning. Took the cable loose at tranny end and it seems to have gone in "too far." I had to spin the cable to get it to back out. Previously I took the cable out at the speedo end to grease it. After greasing I pushed the cable back into the conduit.
I tested the cable and drove the car again, and the cable was turning. Reinstalled the speedometer and not working. I've done this no less than four times and each time, the speedometer isn't working. The speedometer has been tested with a drill and works. Is there a right and wrong end on the speedometer cable or a direction it needs to be installed? Is there a "stop or something that keeps the cable positioned one way or the other? I seem to be doing something wrong and am not sure.
Kevin Essex, CT |
09-26-2023, 04:04 PM | #2 |
Re: Speedometer Cable - right or wrong way to reinstall after lub.
some of the reproductions are too short. I think a 1/4 " long round stock should be installed at the trans.
09-26-2023, 04:39 PM | #3 |
Stock cables are 61 and a half inches long. The cable housing and or the cable could have been replaced over the years so different lengths could have been used. If you can find a speedometer shop, you can get a longer cable made up. Of if your cable measure less than the stock length, you can buy a new cable from Snyders.
09-26-2023, 07:06 PM | #4 |
As Jack said, measure the diameter of the end of the cable find a piece of steel roundstock. Cut off about a quarter of an inch and put that into the hole in the gear first. Have the cable in and tightened at the speedometer end, then install in the turtle end and test drive.
09-26-2023, 08:29 PM | #5 |
this is how they are installed and when testing the drill should be in reverse.
www.whidbeymodelaclub.com Last edited by Gary WA; 12-30-2023 at 02:35 PM. |
09-28-2023, 09:02 AM | #6 | |
Kevin Essex, CT |
09-28-2023, 11:36 AM | #7 |
What, you can't put a round peg in the square hole
Just use a little smaller diameter piece of round stock to cut your spacer from, anything that fits into the square, or find a small pice of square stock |
10-01-2023, 12:06 AM | #8 |
Kevin, just saw your message. You are right if the round stock is too big. You might find a nail that will fit in the square hole at the drive gear. You just need a piece long enough. Maybe 1/4" to push the cable up into the speedo drive.
10-01-2023, 12:12 PM | #9 |
You can also shim the speedometer end of the cable to keep it engaged in the speedo.
