09-23-2023, 09:36 AM | #1 |
Head stud location help.
I’m close to bolting my head down this weekend and was prepping bolts when I noticed a couple of different length shoulders and studs in the pack. I did some hunting and couldn’t really find a location chart and I didn’t take note when I removed the old studs on length etc.
Would anyone be able to point me in the right direction so I don’t fumble the stud location ? The top bolt in the photo is a quantity of ten in the pack the two lower bolts are the ones in question obviously the longer bolts are water neck so they aren’t photographed. |
09-23-2023, 10:04 AM | #2 |
Re: Head stud location help.
the same two sizes are for water neck to head and the longer one is number 8 to hold the cable to distributor if using the bracket..
www.whidbeymodelaclub.com |
09-23-2023, 10:57 AM | #3 |
You should have only one of the longer bolts in your picture for the ignition cable like Gary mentioned. You should have eleven 3 1/2" studs
one 3 3/4" and the two long for the water outlet. |
09-23-2023, 10:58 AM | #4 |
So one of the studs is incorrect
09-23-2023, 11:06 AM | #5 |
I also should mention this is the high compression stud kit.
09-23-2023, 03:05 PM | #6 |
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan |
09-23-2023, 06:26 PM | #7 |
09-24-2023, 07:42 AM | #8 |
I recommend that you incorporate this tip:
Bob Bidonde |
09-24-2023, 08:39 AM | #9 |
Who did you buy the studs from?
I only remember 2 sizes from my high compression upgrade. |
09-24-2023, 10:03 AM | #10 |
A606466HD from Macs
09-24-2023, 06:58 PM | #11 |
Talk to Macs
09-24-2023, 09:25 PM | #12 |
The one with the longer coarse threads is not a head stud. Either made wrong or wrong application. At second thought, it’s the correct length, just has too many coarse threads. I suppose you could use it. Just set it at the proper height and you’ll have threads in your head. Don’t think that would hurt anything.
Last edited by Chuck Sea/Tac; 09-24-2023 at 09:34 PM. Reason: Additional thoughts |
