09-08-2023, 07:13 PM | #1 |
41 Oil Filter Lines
Hi All
I have my original 41 flathead with the partial flow filter. The flexible lines were brittle and unuseable. I saved them thinking a hydraulic shop can just swage the old fittings onto new hose, but haven't had any luck. My early 41 has the banjo fitting and hollow bolt on the timing cover. Are there premade flexible lines available new? |
09-08-2023, 08:20 PM | #2 | |
Re: 41 Oil Filter Lines
09-09-2023, 12:04 PM | #3 | |
The 1941 oil pan and its dedicated return fitting BELOW! Coop |
