08-30-2023, 03:29 PM | #1 |
Cracked Fan!!
While inspecting my A's found a cracked fan!! Oh My Saved a Hood!!
www.whidbeymodelaclub.com Last edited by Gary WA; 12-30-2023 at 02:36 PM. |
08-30-2023, 09:44 PM | #2 |
Re: Cracked Fan!!
Mine looked exactly the same when I changed it a few weeks ago. The Aluminum fan I replaced it with is better balanced and noticeably smoother. Money well invested.
Stickshift 1915 Model T touring 1931 Ford Model AA Flatbed |
08-31-2023, 12:04 AM | #3 |
Re: Cracked Fan!!
Amazing, you of all people running an original fan surprises me!
08-31-2023, 09:08 AM | #4 |
Re: Cracked Fan!!
Broke one back in the 1970,s haven’t trusted since then. No problem with the aluminum ones except sometimes having to grind front of water pump casting to get clearance,as aluminum ones are thicker at inner pulley .
08-31-2023, 09:50 AM | #5 |
Re: Cracked Fan!!
Ditto spdway1
Bob Bidonde |
08-31-2023, 11:37 AM | #6 |
Re: Cracked Fan!!
Marshall |
09-06-2023, 07:47 AM | #7 |
Re: Cracked Fan!!
put that thing on the shelf or in the scrap bin, it's a bomb ready to go off. I put the six blader on and never looked back. I have an original cast iron fan and it sits on a shelf. No way I'm putting that stick of dynamite under my hood again.
"Ain't but three thangs in this world worth a solitary dime, but A Models, Sweet Tea, and Macaroni Pie!" |
09-06-2023, 11:23 AM | #8 |
Re: Cracked Fan!!
Once you crack one and catch it ore disaster...toy never go back to originals
09-06-2023, 11:59 AM | #9 |
Re: Cracked Fan!!
Never ever turn your engine over using the fan! When I installed a new 900$ radiator I changed my late 31 fan blade with the new aluminum ones. Some of the engine vibrations seamed to be lessened. When I restored the original fan I bead blasted it, magnafluxed it, checked it for straightness and balance ( the best shade tree methods possible)
09-06-2023, 01:42 PM | #10 |
Re: Cracked Fan!!
09-06-2023, 11:37 PM | #11 |
Re: Cracked Fan!!
What about the four blade fans? Also I'm running a C head and a three bolt pump, will the new aluminum fan fit this pump shaft?
09-07-2023, 01:26 PM | #12 |
Re: Cracked Fan!!
