08-29-2023, 07:47 AM | #1 |
I have lost it.....
We have probably all done it. You take something apart for for repair or refurbishment and then set an important small part in a "safe" place so you will never lose it......never to be seen again!
I confess. I have misplaced a small part to my 50' F5 COE parking brake hand lever. Its the small, toothed pawl or cam at the bottom of the the hand lever that releases when the hand lever button is depressed to release the brake. It may be part number 51-2786. Anyone know of a source for one? Thanks. Last edited by jms50f5coe; 08-29-2023 at 08:31 AM. Reason: full part number |
08-29-2023, 09:11 AM | #2 |
Re: I have lost it.....
Only lost one part in all the years? Pretty good.
08-29-2023, 10:16 AM | #3 |
Every day. My shop is so cluttered with boxes of parts for my T5 and water pump kits plus boxes of expensive parts I have for projects I'm doing now and in the future plus lots of left overs. I'm scared to lay down a part for fear that it will disappear into the black hole that is my shop.
08-29-2023, 10:39 AM | #4 |
It’s as bad as dropping a small part, nut or bolt and having it go to “ part heaven”.
08-29-2023, 10:42 AM | #5 |
I lost the original seat belts for my (O/T) '67 Corvette the last time I moved.
To add insult to injury, do you have any idea of what those suckers cost? |
08-29-2023, 11:06 AM | #6 |
The earlier Ford parts book shows Truck 1932-47 except 122" WB and COE. |
08-29-2023, 03:05 PM | #7 |
Anyone have an idea where to source one? Part number 51-2786
I would even purchase a complete parking brake handle. I will ask in the want ads also. thanks. |
08-29-2023, 03:37 PM | #8 |
Just be aware of Murphy's Law 278'th (or so) corollary. "You will find your missing part within moments of installing the replacement".
08-29-2023, 04:11 PM | #9 |
Unfortunately I don't have any spares to help you out. I've attached images of the pawl (51-2786) and the sector arm (51-2795) which engages with it so folks can see the part you need.
1935 157" 1 1/2 ton stake truck undergoing full original restoration 1936 131 1/2" panel truck rescue preservation Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America |
08-29-2023, 04:24 PM | #10 |
There is light at the end of the tunnel, I recently found parts I thought I got rid of years ago. Sad part is now I don't have anything they fit.
08-29-2023, 06:37 PM | #11 | |
08-29-2023, 10:38 PM | #12 |
I am not using any of the original e brake parts off my 51 coe. I have it somewhere, will look if you think it will work for you.
08-30-2023, 07:31 AM | #13 |
Flatrod,
Thanks that would be much appreciated. I'll PM you. |
08-30-2023, 06:01 PM | #14 |
Well, I have been rescued of my CRS, the den of antiquity and black hole, inner sanctom of my shop by "Flatrod" up in Alaska.
He is generously sending me the brake pawl that I am in need of. This transaction goes to show all that the "Barn" community has a large number of big hearted enthusiasts! You know who you are! Thanks so much to everyone who responded to my plea for help. Best regards to ALL! |
08-30-2023, 07:18 PM | #15 |
That ain't nothin. Was under '49 last winter changing out the "new" tranny oil for some Sta-Lube API/GL-4 Multi-Purpose Gear Oil 85W90. Needed a wrench to check some bolts on the clutch linkage. Went to the tool chest and FORGOT WHY I WAS THERE...
08-31-2023, 12:40 PM | #16 |
Been there done that many times. Aren't the 80's wonderful. lol
08-31-2023, 04:42 PM | #17 |
Glad I could help. The part is on its way!
09-01-2023, 07:10 AM | #18 |
Been there done that, getting older can be a bummer sometimes, over the hill is still better than under it.
09-01-2023, 07:51 AM | #19 |
So... To recipricate to the generosity of the "Barn" members. I have the following to offer for FREE to anyone in need.
-55' BW T98(?) 4speed syncro transmission. not for flathead I believe. From a bus -55' Dually 2 speed rear end, 12volt, with wheels and old tires. From a bus -Not sure of year, I-6, 223 complete engine with 3 speed transmission. Located in western Washington. I would be glad to disassemble for any seperate parts anyone needs. PM me if you like. |
