08-23-2023, 11:35 AM | #1 |
Tips to remove spyder hubcaps?
Removing & reinstalling spyder hubcaps - Aside from common sense (pry a little, work around the circumference and don't scratch) are there any tips for this job? I think these are '36 hubcaps on '37 wheels? Corrections are welcome.
Thank you, David 1937 V8, four door convertible |
08-23-2023, 11:57 AM | #2 |
Re: Tips to remove spyder hubcaps?
From the backside with a stick is how I used to do it..Make sure you have someone catch it or put a thick towel down.
08-23-2023, 12:08 PM | #3 |
I have one of these and it really works well > https://www.youtube.com/watch?v=mayIT2jQ_G0
Bob Drake Wheel Wizard
08-23-2023, 03:22 PM | #4 |
Make a simple slide hammer with a hooked end. Full control from the front, no prying, no need for access from behind the wheel.
Alan |
08-23-2023, 04:18 PM | #5 |
Tips to remove spyder hubcaps? - DFS |
08-23-2023, 07:13 PM | #6 |
08-23-2023, 08:52 PM | #7 |
This is the way I do it as well. If by myself, I lay a furniture blanket down for them to land on…and yes those are ‘36 Spyders. They would still be correct for your car if it is an early production vehicle.
08-23-2023, 09:20 PM | #8 |
See pics below.
Alan |
08-24-2023, 06:59 PM | #9 |
I have one spyder that seems tight when I install it but has flown off on two successive rides. I heard something about putting weatherstripping behind it…..how??
Tim Carlig |
08-24-2023, 07:56 PM | #10 |
You may want to check to see if the part of the hubcap that covers the spoke is hitting a spoke. Having no clearance on that part of these hubcaps was a problem if you happen to have Bill Hirsch reproductions. Just a thought.
08-25-2023, 12:07 AM | #11 |
Its the clips on the wheel that secure the hubcap.Check those and replace as necessary.
08-25-2023, 07:30 PM | #12 |
Here's a little rig I buggered together. No moving parts, the end that contacts the wheel rim is a piece of wood dowel, the hooked end was heated and hammered to fit the concave edge of the cap. A little tug and off it comes. Easy-Peasycap puller.jpg
08-25-2023, 09:48 PM | #13 | |
