06-12-2023, 12:02 PM | #1 |
Gas tank derusting
I stumbled on this youtube video.Maybe a LITTLE dangerous but impressive.
I haven't tried it but it seems like it will work. https://www.youtube.com/watch?v=UfTZEXxnUJc&t=365s |
06-12-2023, 12:58 PM | #2 |
Re: Gas tank derusting
Looks pretty interesting - I might try it on an older 32 tank that I have.
06-12-2023, 01:11 PM | #3 |
It looks like it worked pretty well. That's probably a good use for electrolysis de-rusting, since it only works by "line-of-sight" between the anode and the surface to be de-rusted. Tank baffles might pose a problem.
06-12-2023, 03:05 PM | #4 |
I used this process to Clean my 40 gas tank a few months ago. Turned out very well. I used a piece of 1/2” steel pipe for the electrode because it gives you more surface area. I installed it through the sending unit hole. Just don’t let it touch the bottom of the tank. Took about three days and I dumped the contents and put in a new batch every day. Had to clean the electrode several times a day. I installed an ammeter in the line between the battery and electrode. When the ammeter falls back you’ll know it’s time to clean the electrode.
06-12-2023, 05:20 PM | #5 | |
06-17-2023, 05:34 AM | #6 |
