06-06-2023, 03:18 PM | #1 |
How much Corn Head Grease?
How much Corn Head Grease will I need when I replace my universal joint in my 46 Super Deluxe?
Thanks Guys. |
06-07-2023, 08:44 AM | #2 |
Re: How much Corn Head Grease?
look in the ford manual how much corn grease does it say to use none. use what the manual says
06-07-2023, 12:02 PM | #3 |
I believe it was about half a tube
06-07-2023, 01:38 PM | #4 |
I remember using a full tube. I think others here have posted similarly.
Cars and metal rust away and are destroyed, but the Word of God will stand forever (Isaiah 40:8, Matthew 24:35). |
06-07-2023, 03:03 PM | #5 |
x2!!!
1952 Ford F1 1965 Ford Falcon Sprint 2007 Ford Mustang GT |
06-07-2023, 03:34 PM | #6 |
06-07-2023, 06:37 PM | #7 |
Good Lord. It is NOT corn grease.
https://www.nirgv8.org |
06-07-2023, 06:51 PM | #8 |
No richard it says soda soap grease if you can find it please post where. Cornheader or semifluid bearing grease is the closest that can be found these days
06-08-2023, 07:16 AM | #9 |
mix 1/2 synthetic grease with 1/2 synthetic trans fluid this combination works great, does not cake up and seems to stay in the bearings of the u-joint
06-08-2023, 08:08 AM | #10 |
You can remove the speedometer turtle and pump grease till it starts coming out the opening.
06-08-2023, 08:13 AM | #11 |
I used an entire cartridge in my Model A.
06-08-2023, 11:55 AM | #12 |
I appreciate all of the information and replies.
Thanks guys. |
06-08-2023, 01:07 PM | #13 |
What are you guys using for a seal on the bell? Cork or an o-ring?
06-08-2023, 02:18 PM | #14 |
I used about a tube and a half of Cornhead Grease and the neoprene o-ring seal.
Car is 1940 Ford. Last edited by 19Fordy; 06-08-2023 at 02:41 PM. |
06-08-2023, 03:21 PM | #15 |
Do you have a size for the o-ring that I could ask the parts guys to get?
Thanks |
06-08-2023, 03:35 PM | #16 |
06-08-2023, 03:41 PM | #17 |
I pint ,CV joint grease is a good modern equivalent
06-09-2023, 10:16 AM | #18 |
Duke: I bought mine 6 years ago on Ebay from this fellow:
https://www.ebay.com/itm/25125522858...Bk9SR-7C0ouUYg Don't forget to install the paper gaskets before you assemble everything. |
06-09-2023, 11:27 PM | #19 |
Thank you 19Fordy,
Marko39- do you have any details on the tube? |
06-10-2023, 08:14 AM | #20 |
