05-20-2023, 01:20 AM | #1 |
33/34 brake cross shaft
Im doing a repair on the brake rods and clevaces on there 33,Im looking at removing the brake cross shaft and springs assembly ,it has 4 bolts and what looks like two rivets each side on the outside support bracket that attach it to the chassis cross member,Is this right,
I have to take these rivets out as well? this is on a RH drive 33. Lawrie Last edited by Lawrie; 05-20-2023 at 09:33 PM. Reason: add photo |
05-20-2023, 04:30 AM | #2 |
Re: 33/34 brake cross shaft
Sure do Laurie and you better take 20 photographs of it so you put it back the way it was.
05-20-2023, 06:15 AM | #3 |
The US (LHD) brake equalizer shaft is held on with 4 bolts and no rivets.
05-20-2023, 06:45 AM | #4 | |
05-20-2023, 08:54 AM | #5 |
The photo below likely was provided to me by Dave Slater. It is the RHD double shaft type where the rear wheels are braked separately from the front brakes in response to local regulations. The two holes in the outer brackets referred to in Lawrie's thread are clearly evident.
05-20-2023, 11:20 AM | #6 | |
05-20-2023, 03:47 PM | #7 |
Thanks , Thats them,,
Todays job is to get it out, One thing that may make it easier ,is the bottom of the rivets are wiped off, probably from miles on gravel roads, And , a picture is worth a thousand words for sure, Thanks Dave and all. Lawrie |
05-20-2023, 04:58 PM | #8 |
Hi Lawrie With our many brake jobs and fitting up our floater kits we have for the sake of time used king pin bushes to repair these shafts ,
05-20-2023, 05:34 PM | #9 |
Thank you Ted, I found a spare in my stuff ,so will look at doing that first,It must be a job to get it all apart.
Hows things ,I was in NZ at Christmas but not up your way, Lawrie |
05-20-2023, 09:27 PM | #10 |
Well, thanks to the help from here, the shaft assy is out, cleaned and ready for repair,
I have 4 holes in the assembly to repair, and most of the cleavaces, I will do this by tig welding the holes shut and re drilling them on the mill. if I cant find good pins, I will make some up. I will also make up 4 bolts that look like rivets for the little brackets Lawrie |
05-20-2023, 10:58 PM | #11 |
NZ is great catching up from Covid lots car shows on ,Actually I am fighting fit ,.,You will hear from me on that later. You got it apart alright a person with your skill it would be no trouble ..Good idea on the turning the rivet head to .I I made some rods for my sedan by forging some bright steel and bending it back on its self and drilling and welding, Ted
05-20-2023, 11:13 PM | #12 |
I have to replace one front rod.But I have some modelA rods that can be made to fit easy.
Lawrie |
