05-11-2023, 09:54 PM | #1 |
6 volt to 12 volt
Are there any YouTube videos showing how to convert my 31 model a from 6 volts to 12 volts. I'm trying to get away from constantly adjusting the spark. I want to keep it looking original. Do I have to change to 12 volts to achieve this.
05-12-2023, 08:52 AM | #2 |
Re: 6 volt to 12 volt
Changing from 6 to 12 or positive to negative ground has nothing to do with adjusting the spark. You would need to change to Model B distributor and that is a whole different can of worms.
You need to ask on the Model A forum. This section is not for car questions.
05-13-2023, 01:21 PM | #3 |
As redmodelt said, you should post in the Model A forum section for better results. Charlie Stephens |
