05-08-2023, 01:58 AM | #1 |
water pump leaking
hello guys, I have a problem with the water pump, is leaking, 1956 272 ci y block ford, I would like to know how to remove the small pipe from the heating, have to pull or unscrew? Thank you for your help
05-08-2023, 08:26 AM | #2 |
Re: water pump leaking
If you are talking about the small by-pass elbow on the water pump you unscrew it from the pump. If it is bad, new ones are available.
05-08-2023, 09:25 AM | #3 |
there's 2 small pipes on the water pump, the second it must unscrew too ?
05-08-2023, 06:49 PM | #4 | |
The nipple attaches to the WP with two cap screws. The tube on the thermostat housing is either cast into the housing or later design has a press-in tube. Does that help?
- AT MY AGE, ONE APPRECIATES A STURDY HANDRAIL - |
05-08-2023, 07:24 PM | #5 |
The tube (nipple) for the heater hose unscrews. It is usually a bent tube.
05-08-2023, 11:55 PM | #6 |
05-09-2023, 03:34 AM | #7 | ||
The heater outlet fitting (on the intake manifold) will screw out as Paul said - If you are describing the heater return nipple on the pump casting itself, it also screws in/out (see 2nd photo).
- AT MY AGE, ONE APPRECIATES A STURDY HANDRAIL - Last edited by KULTULZ; 05-09-2023 at 08:59 AM. |
05-09-2023, 11:59 PM | #8 |
ok thanks KULTULZ
05-21-2023, 11:55 AM | #9 |
i'm changed the water pump by the new one, it don't leak no more and works fine
