04-15-2023, 06:26 AM | #1 |
Pt 2 Model A oil filter test
04-15-2023, 10:01 AM | #2 |
Re: Pt 2 Model A oil filter test
Thanks!
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
04-15-2023, 10:35 AM | #3 |
Thanks Randall. If nothing else, this shows that when the filter is full, there is no lag time in oil pumping to the valve chamber. No issues with the anti-flow back valve. No need to drill or modify the filter.
04-15-2023, 11:06 AM | #4 | |
Hopefully this puts the final nail in that coffin. |
04-15-2023, 12:41 PM | #5 |
I thought it was DOA ! :-)
04-15-2023, 05:05 PM | #6 |
I still hear people saying that overheating can be cured by trimming the impellor and slowing down he water flow through the radiator. That has been debunked sooo many times. Hopefully, at least some people will take note.
04-17-2023, 08:19 AM | #7 |
It will never happen as long as the Social Media pages on Model-As are still around. The amount of misinformation, -and even disinformation spread on those pages is unreal.
04-17-2023, 09:44 AM | #8 |
I acknowledge that there is to many questions more than one good / workable answer. However unscientific answers drive me crazy, especially the old wives tales passed along from generation to generation.
Bob Bidonde |
04-18-2023, 05:44 AM | #9 |
Thanks Randall
For all the so called experts who said the oil filter was useless you can put this video in you pipe and smoke it lol |
04-18-2023, 08:50 AM | #10 |
04-19-2023, 08:16 PM | #11 |
Just for conversation sake, how much oil leeched into the valve chamber during the test? This would tell just how much oil is directed through the filter.
04-20-2023, 08:11 AM | #12 |
I'm confused. I just saw Randall's previous video where he tested the passive oil filtration system. When the oil is cold, there is a fair amount of oil going through the filter, which looks fine to me, but when the oil is up to temperature, hardly any oil is going through the passive oil filter system. I understand that the passive oil filter system is less effective than the full filter system, but the amount of oil when the engine is warm seems very small to me. Since I have just partially overhauled my engine (original babbitt bearings) and installed the visually more attractive passive oil filter system, I am now wondering whether the passive oil filter system is sufficient at all or should I switch to a full filter system after all? Has anyone found a similar video that confirms Randall's insight into the passive oil filtration system, or am I panicking unnecessarily?
04-20-2023, 09:30 AM | #13 | |
The actual bypass filters are mounted below the valve chamber, so gravity works with them, not against them. |
