#1 |
https://www.ebay.com/itm/14491336517...emis&media=SMS
Is this the right T5 for the T5 conversion to Ford V8 Flathead on my 35? My engine is a 1949 8BA. Add says its for an 96-99 Chev S10. I think thats the one with the short tail so shifter position is right?
Nomad |
#2 |
To me ,NO.
Should look like this:Its an S10 and shifter forward. |
#3 |
#4 |
Hey Tony .... You knew The Coopman was gonna be all over this one. Sheldon in post #2 is correct. That trans in the eBay ad AIN'T nothin' like what you want. And the T5 in Sheldon's post IS the correct T5 CASE & TAIL HOUSING for what MOST guys are trying to do with T5s in these old Fords, which is a T5 with the "S10 Tail Shaft Housing", allowing the shifter to sit quite a bit forward of where MOST T5 shifters sit. But, as many of you have heard me preach a dozen times before, you will likely be really DISAPPOINTED WIITH THE GEAR SET that is inside the "S-10 T5". One more thing ..... you haven't exactly confirmed that you want to convert over to an open drive set-up, 'cuz the trans that Sheldon showed above will require an open drive shaft and the rear end conversion to support that. Tony ..... I want you to click on the link directly BELOW. It is a far better description of the T5 that you want to assemble to use in one of these old Fords. IT'll answer a lot of questions for you. Then, we'll talk! https://www.fordbarn.com/forum/showp...49&postcount=7 Coop . |
#5 | |
![]() Quote:
#6 |
#7 |
With the manual speedo drive S10 T5's becoming increasingly hard to find I have a number of the T5 trans I sell using the electronic sender. Many of my customers have used Cable X with some success. Not the best alternative but does the job.
#8 |
I like to ise the Ford style case as the adapter to the flathead is nly $160 and the and the box is stronger. Biggest problem is the rear axle. Rather than use the stock ford unitconvert to open drive spicer 35/44 some of these have posi units and are much cheaper than the ford 8". I'd stay away from the 9" very heavy poor ride quality.
Gramps |
#9 |
Thx all, glad I checked! Got it! I think I do remember now from some of the older threads seeing the one u all showed in online info & pics! When I do it I will b going w open drive shaft & Jeep GC Posi rear Gramps suggested.
Thx & best!
Nomad |
#10 | |
![]() Quote:
Gramps' Gran Cherokee rear with about 100 lbs of brackets and garbage welded-on. That rear cover covers some really wimpy gears. YOU need disc brakes in rear? ![]() Nice and clean '57 Ford 9" rear. You'd never know the difference by driving the two. Try finding reasonably-priced (or available) parts for that Cherokee rear! Coop . |
#11 |
#12 |
Cable X converts the transmission electronic pulse signal into a mechanical signal when it goes thru their converter box and turns a short speedometer cable that hooks to the speedo.
#13 |
#14 |
Thx Coop! Good Info! Im a ways out on that project! But will file it! The reason it came up was the tranny I saw looked clean & reasonable but also the wrong one,
Nomad |
#15 | |
![]() Quote:
And ya sure don't want to end-up with hydraulic shoes/drums in front with discs in the rear! Coop . |
#16 | |
![]() Quote:
Nomad |
#17 |
The rear swap is tied to my wallet. Thr 9&0 in rears are very expensive, so that eliminates them for me. The spicer 44 from a jeep GC with posi is very cheap Buck wise andputting it on leaf springs do different. I don't think disk brakes are necessary on the rear. Now the weight of the rear axle isn't that important, but in a light car hard to control with shocks on Vermont roads.
Gramps PS the 44 isn't that light either the 35 is better, but hard to find with psi. G |
