03-16-2023, 12:50 PM | #1 |
Messko Radiator Cap for Model A
How can I take the Messko Radiator Cap off a Model A? I have tried, but do not want to break it. Is there a technique? See Pics. Thanks, Jim
03-16-2023, 02:26 PM | #2 |
Re: Messko Radiator Cap for Model A
It should release like other caps. Try to get it off using a strap wrench. One of mine is tough to remove and comes off fairly easy using the strap wrench.
03-17-2023, 09:59 AM | #3 |
Thanks. I have read that some of these caps have an anti theft set up on them. If this cap is set up that way, is there something else i need to do? I've tried turning it with a strap wrench, lifting while turning, still not coming off.
Thanks |
03-17-2023, 12:49 PM | #4 |
Does the cap turn? I put an O-ring on my quail and I have to press down as I turn the cap.
TOB |
03-17-2023, 05:41 PM | #5 |
Check if there is a small Allen bolt head on the backside of the cap. Some caps use that as an anti-theft device, as it's almost invisible unless you know what to look for.
Marshall |
03-18-2023, 10:39 AM | #6 |
03-22-2023, 09:50 AM | #7 |
Thanks for the help everybody. I finally got the radiator cap off, a little master blaster and some lite tapping on the cap and she came off. She was rusted to the filler neck.
03-22-2023, 10:54 AM | #8 |
Small victories are sometimes the greatest!
03-22-2023, 12:08 PM | #9 |
Being patient and careful generally pays off.
