01-09-2023, 09:14 PM | #1 |
Need help
There were some articles on upgrading a banjo axle to modern axles and brakes.
I need help finding the articles. Appreciate any help. Stephen |
01-09-2023, 09:48 PM | #2 |
Re: Need help
Something like this? https://www.hotrodworks.com/product/...e-ford-brakes/
01-09-2023, 10:19 PM | #3 | |
Re: Need help
01-10-2023, 09:53 AM | #4 |
Re: Need help
Yes an upgrade like the one pictured. I am aware of Hot Rod Works setup. There were some articles posted in the past on Ford Barn by members who have done the machining / fabrication themselves, however I can’t seem to find their posts.
01-10-2023, 11:58 AM | #5 |
Re: Need help
Here's an article on the HAMB. https://www.jalopyjournal.com/forum/...-axles.380478/
01-10-2023, 05:32 PM | #6 |
Re: Need help
( since I believe there is no provision to change, edit, a title ) using your need in he heading. Should bring a quicker response Kudos to Bob C and Jalopy Journal
Enjoy yer day. Tom Hate can't fix what it started. Last edited by A bones; 01-10-2023 at 05:38 PM. |
01-10-2023, 09:41 PM | #7 | |
Re: Need help
Opinions gratefully appreciated. Thanks, Stephen |
01-10-2023, 10:16 PM | #8 | |
Re: Need help
Having converted a lot of banjo rears to drop in axles for the street and for the family race car which has run as fast as 229 MPH with our simple back yard conversions. I can help you with some information. The hot rod works side gears are custom made only in the area where they mesh with the early Ford spider gears. The hub diameter is not special its the same size as the 8 inch and 9 inch Ford side gears. If your idea is to use the 7.5 side gears your going to be in uncharted waters. Question are you sure the 7.5 side gears will mesh correctly with the Ford banjo spiders? Never had a need to try them so I'm not sure. Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
01-10-2023, 10:31 PM | #9 |
Re: Need help
If you search the hamb you will find many discussions about this topic. In one, JSEARY, whom we have not heard from since June, had some other side gears he was using that he claimed fit as good as the Idaho ones. Sorry, I cant remember what he was using, but jerry was no dummy
01-11-2023, 06:29 PM | #10 |
Re: Need help
I'm reluctant to post this, but JSeery was a frequent contributor here on the 'Barn and I took every post he made to heart. This obituary matches his biography on his profile. It looks like Jerry and his mother and father all passed within a couple of years. My condolences to their family.
https://www.legacy.com/us/obituaries...ry?id=36924557 |
01-11-2023, 06:34 PM | #11 |
Re: Need help
40cpe > "I'm reluctant to post this, but JSeery was a frequent contributor here on the 'Barn and I took every post he made to heart. This obituary matches his biography on his profile. It looks like Jerry and his mother and father all passed within a couple of years. My condolences to their family.
https://www.legacy.com/us/obituaries...ry?id=36924557" Jerry Seery 1947 - 2022
