Old 12-09-2022, 06:22 PM   #1
Smokedtires
Smokedtires's Avatar
Default 5.5 Snyder head, what else is needed or recommended?
Hello all, I bought my 30 Roadster last June and put almost 600 miles on it before putting away for winter. I'm interested in more torque for hill climbs while keeping everything appearing stock.
My question is, should the Zenith's jets be increased in size to accommodate the higher compression? Any other considerations to go with the new head? Currently it is restored with everything in stock form.
Thanks, looking forward to hearing from the pros here.
Smokedtires is offline   Reply With Quote
Old 12-09-2022, 07:24 PM   #2
Ray64
Ray64's Avatar
Default Re: 5.5 Snyder head, what else is needed or recommended?
I have a 5.5 on mine and i dont see a need more carburation
Ray64 is offline   Reply With Quote
Old 12-09-2022, 07:58 PM   #3
Gary WA
Gary WA's Avatar
Do not increase the jets. But a high comp head works great with stock engine.
www.whidbeymodelaclub.com
Old 12-09-2022, 07:59 PM   #4
Stingray70
Stingray70's Avatar
I have the Snyders 5.5 head on an otherwise stock car. It made a huge difference while driving here in the NC mountains. I run the GAV richer than with the stock head. No need to change jet sizes.
1930 Standard Coupe
Stingray70 is offline   Reply With Quote
Old 12-09-2022, 08:46 PM   #5
dansluck
Send a message via AIM to dansluck Send a message via Yahoo to dansluck
The 5.5 or the 6.1 from Synders is a good choice. I have both and a 7.1 Winsor which is aluminum. I live in the Sierras and prefer the the cast iron 6.1. Good luck and have fun.
Dan
dansluck is offline   Reply With Quote
Old 12-09-2022, 09:02 PM   #6
GPierce
GPierce's Avatar
Actually you will burn less fuel as the higher compression is more efficient.
GPierce is offline   Reply With Quote
Old 12-10-2022, 05:25 AM   #7
Bruce of MN
Bruce of MN's Avatar
You'll have to learn to work the advance lever more. My 6:1 needs less full advance than the stock head. I limit the travel with this.
Bruce of MN is offline   Reply With Quote
Old 12-10-2022, 07:50 AM   #8
ronn
buy the 6.0. the price difference is negligible.
Old 12-10-2022, 09:47 AM   #9
Smokedtires
Wow, this is great to know. Thank you everyone.
Old 12-10-2022, 11:20 AM   #10
Terry, NJ
Terry, NJ's Avatar
An old tried and true method of increasing HP is to bore out your intake manifold to 1.125 + and run a B carb on it. It will gain you about 3-4 HP. I know it doesn't sound like much, but with a 40 HP, it a little less than 10%. Another way is to install an Aries muffler.
Terry
Terry, NJ is offline   Reply With Quote
Old 12-10-2022, 11:36 AM   #11
Bob Bidonde
Bob Bidonde's Avatar
I have both hi-compression heads, the 5.5 & 6.0:1. As has already been said above, you will need less spark advance with these heads, especially the 6:1 head. With the 5.5:1 head, I found that I could only use 10 of the 12 spark lever notches without knocking (87 Octane Gas), so I pull the spark lever down 2 notches when timing the engine. For the 6:1 head, I pull the spark lever down 5 notches when timing the ignition, so I can use the full range of the quadrant. Averaging 50 mph with my Victoria, the 6:1 head delivers 23 mpg.
Bob Bidonde
Old 12-10-2022, 02:25 PM   #12
nkaminar
nkaminar's Avatar
In my opinion, the 6.0 head from Snyders has a better combustion chamber design than the 5.5 head from them. It is more like the high performance heads used on the Harley Davidson and Briggs and Stratton engines. There is more to head design than the compression ratio.
Old 12-10-2022, 04:57 PM   #13
Smokedtires
Okay. I'm hoping for this to be a spring upgrade for next driving season. Thanks all.
Old 12-11-2022, 07:12 AM   #14
chap52
chap52's Avatar
I ran a 6.0 from Snyders and loved it... Chap
chap52 is offline   Reply With Quote
Old 12-12-2022, 11:47 AM   #15
Paragon
OK, my low mileage engine that was stored for 30 was recently rebuilt by a local rebuilder and the babbitt was in good shape. The engine performs well, yet I'm looking for a bit more performance when climbing grades. I am considering converting to a 5.5 or 6.1 HC head. I'd prefer not to change the studs as they were not changed when the engine was rebuilt. Will the original studs work w/the 5.5/6.1? Any experience?????
Paragon is offline   Reply With Quote
Old 12-12-2022, 12:38 PM   #16
katy
katy's Avatar
Should be OK, as long as the block and head are FLAT, they're still torqued to 55 ft-lbs w/either head.
Old 12-12-2022, 12:55 PM   #17
Steves46
Steves46's Avatar
I am using the same studs for my Snyders 5.5 with no issues. Just make sure the studs are in good shape.
If it aint broke, don't fix it!
Steves46 is offline   Reply With Quote
Old 12-12-2022, 01:27 PM   #18
alexiskai
alexiskai's Avatar
Clean those upper threads and always use new nuts. Biggest risk is that corrosion on the stud threads leads to some studs having low clamping force because too much torque went into overcoming friction.
Old 12-13-2022, 10:13 AM   #19
Bob Bidonde
I have both the 5.5:1 and the 6.0:1 heads on my A's and both run with standard studs. Does anyone know how much the combustion (explosive) pressure increases with these heads?
Bob Bidonde
Old 12-13-2022, 11:17 AM   #20
AzBob
Bob, My .040 over engine with Snyder's 5.5 head had the following cylinder pressures.(engine warm.) 76, 76, 76, 75 psi.
When I had the engine rebuilt, I replaced the 5.5 with the 6.0 head. Cylinders were bored to .060 over. Cylinder pressures are now 105, 104, 105,106 psi.
Not exactly an apples to apples comparison as the bore increase also increases cylinder pressure to some extent.
AzBob is offline   Reply With Quote
