11-24-2022, 05:33 PM | #1 |
New Rebuilt Engine - Pistons not moving
Hello
I have a rebuilt engine for 1930 Model A and finally finished install last week. Today went to crank the engine by hand to set the timing and could not find the dimple on the timing gear, took out a spark plug #1 and hand cranked, piston is not moving but the hand crank turns. It's been about 6 months since I got the engine back from the rebuilder. Should I take out plugs and remove starter, oil the cylinders and then try again? Mark Underwood Gig Harbor, WA |
11-24-2022, 05:43 PM | #2 |
Re: New Rebuilt Engine - Pistons not moving
MMMM So I take it the engine has not been fired since you got it back. I would pull the rest of the plugs and slowly hand crank again to see if all the pistons are in fact moving. Did you get a warranty from the builder? Best contact him before anything is removed to avoid any potential warranty issues.
11-24-2022, 05:56 PM | #3 |
Busted crankshaft? That would be odd,. Was the timing gear moving?
11-24-2022, 06:44 PM | #4 |
Yeah, put a flashlight in through the hole for the timing pin and see whether that gear is moving. That’s the most likely spot for problems. You can also put the car in gear and push it back and forth, see if the piston moves.
11-24-2022, 07:01 PM | #5 |
Are you sure you were looking at piston and not the valve? you could remove side timing cover and look to see if indeed timing gear etc are moving. Or like stated above push car in gear, might be just tight but you said couldn't find the dimple so i assume it is turning over.
www.whidbeymodelaclub.com |
11-24-2022, 07:12 PM | #6 |
11-24-2022, 07:46 PM | #7 |
11-24-2022, 07:53 PM | #8 |
11-24-2022, 08:21 PM | #9 |
If the piston is near the top or bottom it takes quite a bit of crankshaft movement before the piston moves a lot. I think you need to re-check this, the crank turning with no piston movement on a rebuilt engine is really pretty close to an impossibility unless it was gross incompetence by the builder. Even gross imcompetence really doesn't cover that bad of an error.
11-24-2022, 10:16 PM | #10 |
11-24-2022, 10:28 PM | #11 |
11-24-2022, 11:07 PM | #12 |
A broken crankshaft is not at all unknown but as has been said, on an engine that hasn't even run????
I think we need to be looking elsewhere.
11-25-2022, 01:09 AM | #13 |
Well one thing for sure, it will be interesting what gets found.
11-25-2022, 02:18 AM | #14 |
Take the small timing cover off be aware there is a oil pan bolt up from underneath , When you turn the crank you can see if the timing wheel rotates . This is a very very odd never ever heard of this before .
John in rare sunny morning Suffolk County England . |
11-25-2022, 03:10 AM | #15 |
Pull the oil fill tube out and you can see the crankshaft you may need a flashlight you will be able to see the crankshaft moving or not moving
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
11-25-2022, 09:03 AM | #16 |
perhaps it is stuck valves, they are more visible through the spark plug hole, there still isn’t a reply from the original poster
11-25-2022, 09:07 AM | #17 |
I would not take anything apart just yet. As others have said, a piston not moving is highly unlikely. Remove all four plugs. Normally you would do this to inspect the plugs prior to timing. Now the engine should turn over easily. Hold you thumb down on one of the spark plug holes and have someone hand crank the engine a few turns while the thumb is in place against the hole. If no resistance is felt get in touch with the engine builder. If you start removing parts your engine builder will probably be hard to deal with.
11-25-2022, 09:19 AM | #18 | |
11-25-2022, 10:42 AM | #19 |
Weird. Is the pulley in front moving when hand cranking? Maybe the hand crank is not engaging correctly? I am also interested in learning what is found.
Try turning the engine over with the flywheel ring gear and a screw driver, or the starter.
11-25-2022, 04:38 PM | #20 |
The OP has only 2 posts. Is this thread serious or is he just stirring us up?
