11-17-2022, 07:33 PM | #1 |
Opinion wanted
I’m building a 34 p/u flathead powered, t-5 transmission, banjo rear with 4.11 gears. The block is a 8ba block it has a 3-3/8” bore with 1.6” valves, the cam is a regrind 286 duration and .380” lift. I will be using a 3-2 intake. My question is what stroke would be good? 3-3/4” = 268, 4” = 286, 4-1/8” = 295, or 4-1/4 = 304. I want an engine that is street-able but fun to drive. Give me your opinion and WHY.
Thanks, Stephen |
11-17-2022, 09:01 PM | #2 |
Re: Opinion wanted
The best stroke is the most you can afford. More is always better.
The cam you have will be best suited to a larger cubic inch engine. 304 or larger. A 3/8 bore in most 8ba blocks leaves enough for at least 2 rebuild bore jobs. It is always a good plan to sonic test before any bore job. There is no down side to more cubic inches other than it takes a bit more work for the port job. It needs to be BIG and well matched to the manifold and headers. The other equipment you list will work fine. With big cubic inches you need a very good ignition like a mag or capacitor discharge type. |
11-18-2022, 01:08 PM | #3 |
Re: Opinion wanted
3.78 rears gears might be more driver friendly. Makes no difference. The old lady in the wore out KIA will still leave you at the light.
11-18-2022, 02:12 PM | #4 |
Re: Opinion wanted
I'd just go with a Mercury 4" crank. I don't think the extra cubes are worth the expense. This is the combination I run (286 CI). WC T-5 and a Maverick 8 inch rear end. Easily keeps up with the crazy interstate drivers if necessary. Cruise at 70 at about 2,100 RPM.
11-18-2022, 03:55 PM | #5 |
Re: Opinion wanted
Pete nailed it. Listen to him. He knows. Be sure the cam you have is what you want.
11-18-2022, 04:02 PM | #6 |
Re: Opinion wanted
11-18-2022, 04:17 PM | #7 |
Re: Opinion wanted
The Flathead in my 40 Convertible is bored to 3 3/8 with a 4 1/8 stroke crankshaft. The only reason I didn’t go with a 4 1/4 stroke is because back when I built that engine they weren’t readily available. Has a Isky Max1 cam with three Stromberg 97s with a T5 transmission and 3:50 gears in the rear. That engine pulls really good , has lots of torque. The 40 is heavy compared to your pickup. I think 4:11 would be a mistake in your pickup.
11-18-2022, 05:01 PM | #8 | |
Re: Opinion wanted
Well I'll be....! As you MAY know, I'm a huge advocate of the T5 transmission behind a Ford flathead. I never had a clue that your convertible has a T5 in it. Could you possibly take a few minutes to explain to the whole world just how much more fun that T5 has made that car to drive, over and above the Ford 3-speed? Do you know any of the info on the gear ratios in your T5? Coop . |
11-18-2022, 05:34 PM | #9 | |
Re: Opinion wanted
11-18-2022, 06:41 PM | #10 |
Re: Opinion wanted
11-18-2022, 06:48 PM | #11 | |
Re: Opinion wanted
11-18-2022, 07:55 PM | #12 |
Re: Opinion wanted
Cam 286 duration @0”, 240 duration@ .050”, lift .380”.
we T-5 Mustang tag # 238; 1st 3.35, 2nd 1.93, 3rd 1.23, 4th 1.00, 5th .73 Tire diameter 30” with 4.11 gear in od 2000 rpm (approx) @ 60 Thanks for those who gave an opinion. I agree cubes are nice but for a street engine is 4-1/8 or 4-1/4 stroke worth it? I agree an graded Ignition is definitely a must |
11-18-2022, 08:21 PM | #13 |
Re: Opinion wanted
More stroke More poke. Yes it’s well worth it. That cam may be a turd in a small engine I’m guessing it’s a single plane cam.
11-18-2022, 08:24 PM | #14 |
Re: Opinion wanted
Yes there are lots of experienced folks here and I'm enjoying this post along with you. Would love to install a T-5 in my heavy truck based woodie, and I see here one from an S-10 might be the ticket for me in this hilly place. Always wondered abut a 9 inch too. So bring on the opinions, they will benefit more than just the OP. Just don't ask for opinions on motor oil. We don't have enough popcorn in our pantry.
11-18-2022, 09:28 PM | #15 |
Re: Opinion wanted
I value your opinion. You are much more knowledgeable about cams than me. I’ll attach a pic of the cam card. What would you recommend?
11-18-2022, 09:50 PM | #16 | |
Re: Opinion wanted
Ken.... Thank you for the info update! There was no doubt in my mind that you would speak swimmingly of the improvement in the driving experience with the T5. With all those gears to choose from, along with the synchronizers on EVERY gear, it'll pull like crazy while keeping the REVS right there in that happy torque band. Ken, you already know how much more smile a Mustang or a Camaro close-ratio gear box with the well-spaced gears would put on your face. Listen-up guys, all this from a Ford Barner that knows well what he's talking about. Coop . |
11-18-2022, 10:05 PM | #17 | |
Re: Opinion wanted
11-19-2022, 10:43 AM | #18 | |
Re: Opinion wanted
11-19-2022, 11:09 AM | #19 |
Re: Opinion wanted
Sounds quite expensive fpr a street engine. However the 296 was a very common displacement back in the day, I have one as a spare. For street the cam is a little much. The late T-5 has an inexpensive adapter , so this will keep the cost down.After yoi blow the rear, replace it with a ford 8", with 3.73 gears and a posi.
Good luck Gramps |
11-19-2022, 11:43 AM | #20 |
Re: Opinion wanted
