#1 |
Have a '31 Coupe. The gears shift ok but the clutch pedal is nearly completely out before the gears engage. Same situation for all gears. What do I need to adjust?
Thanks. |
#2 |
Here is an older thread on the subject.
https://www.fordbarn.com/forum/showthread.php?t=164307 Woodrow describes the adjustment he made in post #11. Here is a picture of the "gizmo" Woodrow refers to...the threaded portion is circled.....
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
#3 |
How much free-play do you have ? I'll kind of assume you have none. Should be 1.0-1.5".
1955cj5 shows a link how. |
#4 |
One inch play at the top is the specification. Before you adjust the clutch, check the parts shown in the picture above for cracks. Push on the pedal to see if any cracks open up under pressure.
#5 |
