10-04-2022, 02:34 PM | #1 |
felt seal 94 carb.
the felt seal on the acc. pump shaft follows the shaft what holds it in place? jack.
10-04-2022, 02:41 PM | #2 |
Re: felt seal 94 carb.
I'm not sure there is a felt seal on a 94 carb. None of mine have any..
Is it a 97? |
10-04-2022, 03:03 PM | #3 |
I just rebuilt two 94’s and each kit had a small round felt piece that came with them. During tear down, there was no felt piece anywhere. They are in my pile of parts, I didn’t use it.
10-04-2022, 03:29 PM | #4 |
no it;s a94 carb. kit from rock auto.
10-04-2022, 05:01 PM | #5 |
There is supposed to be a long spring on the accel pump rod and a small thin washer at the bottom of the spring to go against the felt seal. The spring tension holds it all in place and acts as a return spring for the pump rod/piston also.
The felt seal is there to help avoid fuel dripping from the pump rod when the fuel in the bowl sloshes in that area. Mike's Carburetor Parts online may have a video of the Holley 94 assembly showing the spring and location. Sal |
10-05-2022, 08:14 AM | #6 |
10-05-2022, 08:18 AM | #7 |
What a bunch of knowledge on this site. Thanks, now I have to take it apart again! Charlie Price’s video didn’t show that procedure.
10-05-2022, 10:29 AM | #8 |
Thanks scicala mike's is the place, jack
10-05-2022, 05:17 PM | #9 | |
Just a small thin washer to hold in the felt seal. Sal |
03-05-2023, 10:46 PM | #10 |
That round felt seal comes in the rebuild kits for all 8BA, Ford EBU and Holley 2100 "bugsprayer" type carbs.
The best way to install it I found is to press the felt seal into the recess in the bottom of hole for the accelerator pump actuating shaft. Then push your accel pump shaft into the hole in the main body from above while holding the felt seal in place with your thumb and poke the shaft through. The seal will stay in that recess at least initially. I have them on my Ford EBU carbs. Prior to installing the accel pump shaft/assembly, I rub lubriplate all down that bore thru the main body that the accel pump shaft goes into. That lubricates the inside of the felt too once the shaft is installed. For Holley 2100's and Holley 2110's, they don't have that bore at all. It's just a big cavity, so there is no reason for lubriplating the shaft. Sal says there is supposed to be a thin washer that holds that felt in the recess. If so, it doesn't come with the rebuild kits and all three of my EBU's never had that washer. Also, the instruction sheet that comes with the kits does not show a washer for that felt. Gonna look at the Ford shop manual and see if they show it. I run mine daily and will keep an eye on that felt and see if it works it's way out of the recess. |
