08-08-2022, 06:21 PM | #1 |
Removing steel sleeves
What is the easiest way to remove steel sleeves from a 99-T block, I recall reading .080 pistons can be installed once the sleeves are removed-?
08-08-2022, 06:51 PM | #2 |
Re: Removing steel sleeves
I just did that , ran 4 or 5 mig beads quickly inside the sleeves, took a sharp pin an drove it under the bottom edge enough to be able to lift the sleeve then used a heavy hammer and brass drift on the up turned edge and drove them out.
Took longer to type this than to do it. kurt |
08-09-2022, 05:22 AM | #3 |
08-09-2022, 08:53 AM | #4 |
I wouldn't buy anything until the bores are checked out and the machinist knows how far out you need to go to get them round.
08-09-2022, 11:41 AM | #5 |
